Fitting a diesel heater and low coolant alarm
andrewdean
Post by andrewdean » Fri Apr 21, 2023 11:22 am
I am doing a couple of jobs at the moment.
Fitting a low coolant alarm
And fitting a Chinese diesel heater.
First question... which fuse do I tap into for my alarm?
Next, I will try to upload a picture!
I want to put my heater under the passenger seat but there is a load of garbage from the AC which is disconnected...so can I just chop it all off so I can fix the heater to the frame easily...?
Also does anyone know where I can get a bracket? All sold out on the internet.
Regards
Andrew tel 07742423193 call me if you want
andrewdean
Re: Fitting a diesel heater and low coolant alarm
Post by andrewdean » Fri Apr 21, 2023 11:27 am
How do you upload a picture to this chat thread?
Post by g8dhe » Fri Apr 21, 2023 11:47 am
If you want to add images then look down below the text input area and you will see "Options" and "Attachments" Take attachments and then
"Add Files" select the image and choose "Place inline".
For fusing the Coolant alarm use a mini-piggy back fuse holder and the middle row of the internal fuse box far right any of the three fuses Red 10 Amp, Yellow 20 Amp or Green 30 Amp, you will only need a low current 5 Amp or less fuse for protecting the actual wire to the alarm itself.
The bits under the passenger seat need to be moved around to make space see this link for various positions depending on engine/LPG etc. http://www.g8dhe.net/bongo_images/Heate ... ol_bongos/
andrewdean
Post by andrewdean » Tue Apr 25, 2023 1:44 pm
Below is a pic of the space under the passenger seat where I will put my heater.
Most of what is there I think is redundant cooling system stuff....can i just bin it?
Mine is a Nreg 2.5 litre diesel.
Ps... fitted the alarm no worries...
Now heater...it's cold!!!!
andrewdean
Post by andrewdean » Tue Apr 25, 2023 1:47 pm
Picture.... hopefully ....can't find the. Place in line tab!?
andrewdean
Post by andrewdean » Tue Apr 25, 2023 1:48 pm
I don't use the air conditioning and the belt is removed
Post by g8dhe » Tue Apr 25, 2023 2:52 pm
The parts are not part of the Air Con, they are parts of the engine cooling and emission system including vacuum pipes that control the engine, you just need to reposition them around the supports to give the necessary room to mount the heater. Do not ditch the bits !!!
andrewdean
Post by andrewdean » Tue Apr 25, 2023 7:50 pm
Ah...just in time!
Ok they will all be repositioned..
Any clues on adding a picture....it says it's 2.1MB does that affect anything?
Post by g8dhe » Tue Apr 25, 2023 10:00 pm
In my first post I included a link to pictures taken by others of their installations, if you click the link you can view the images of the areas under the seat.
andrewdean
Post by andrewdean » Tue Apr 25, 2023 10:17 pm
Yes I saw your pictures but I don't know how to upload any myself!
Also I don't know how to put a new post up on the forum.
I need to know which is the best cycle rack to get...needs to be for 3 or 4 bicycles!
Post by g8dhe » Wed Apr 26, 2023 8:36 am
To add a picture;
Open a reply, below the input area
Click "Attachments", Click "Add files" from your machine/network, click "Place inline" the code will appear in the input area.
Click Preview and you can see what the post looks like before continuing the text or more pictures.
Post by g8dhe » Wed Apr 26, 2023 8:40 am
To start a new post, go to the relevant forum;
Click "New topic" and fill in the heading, then fill in the text area with text and whatever else is needed.
andrewdean
Post by andrewdean » Thu Apr 27, 2023 1:24 pm
Does anyone know where I can get the bracket required to attach my Chinese diesel heater under the passenger seat.
I can't find one on the internet they appear to be sold out!
Post by g8dhe » Thu Apr 27, 2023 2:23 pm
If your on Face Book then Dave Westgarth is your man https://www.facebook.com/groups/2529055 ... l%20heater
Roy748
Post by Roy748 » Thu Apr 27, 2023 4:29 pm
Hello
I have a diesel heater mounting plate, requires a 138mm hole cut in the floor. If it's of use private message me.
