Abs sensor alternative
Weavy
Post by Weavy » Mon Mar 16, 2020 2:24 pm
Hi guys my abs lights come on done a test and code is 11 so being the driver's side sensor I've looked around and I see you can fit a ranger sensor im wondering if anyone has fitted one also what info for the sensor if needing to be a certain yr or anything ty
Re: Abs sensor alternative
Post by g8dhe » Mon Mar 16, 2020 2:50 pm
There are several discussions and ideas for repair / replacement but sometimes a bit of a pain to locate due to the lack of searching available on three-letter acronyms! See here for starters viewtopic.php?f=3&t=74306
Weavy
Post by Weavy » Mon Mar 16, 2020 6:53 pm
Ty Geoff just looked through that kink and also the link to the Russian site can't really see what in looking for but I'll keep hunting not is in June so got till then. But not looking forward to paying 200 point for something younger for 30 for other cars
g8dhe wrote: Mon Mar 16, 2020 2:50 pm There are several discussions and ideas for repair / replacement but sometimes a bit of a pain to locate due to the lack of searching available on three-letter acronyms! See here for starters viewtopic.php?f=3&t=74306
brianK
Post by brianK » Thu Mar 24, 2022 9:36 pm
I have just replaced my nearside ABS sensor with a Daewoo Lanos /Nexia sensor A39-10456266 less than £6.00 on e-bay ,requires wire's altering and mods to the fixing bracket but well worth doing .
TheLongRoad
Post by TheLongRoad » Fri Mar 25, 2022 7:20 am
@BrianK. If yu fancy doing a write up with some more detail of the modifications I’m sure that would be appreciated by forum users.
2002 Friendee 2.0 ltr Petrol.
brianK
Post by brianK » Sat Mar 26, 2022 12:06 pm
ABS alternative sensor. first assemble you're parts 1, Daewoo Lanos (1997-) Nubria (1997-05) ABS wheel sensor left or right not important as you will be cutting off the metal bracket . E-Bay item 334132988683 price £5.43.download/file.php?mode=view&id=881
2, 12v 2Pin cable wire connector plug E-Bay item 363742845394 £5.99 for 5.
Take the sensor and carefully cut off the metal bracket taking care not to cut the plastic sensor.Image
take the male part of the cable connector and remove the red clip at the front of the plug exposing the contacts, then push the wires from the back and remove the contacts with the wires attached out of the plug. throw away the plug , attach the wires and contacts to the sensor . Image Bond the connectors and wires to the sensor with JB weld - set aside to cure (overnight).Image
this can be disregarded if you can get you're hands on a daewoo abs sensor plug ( good luck with that one). Take another plug wire connector and solder the wires to the ones from the sensor now you have a sensor connected to a plug .Image
Remove you're original sensor be careful not to shear off the retaining bolt , cut the wire to the original sensor close to the sensor ,the sensor will be destroyed during removal from the original sensor you will need to retain the metal bracket as this will attach the new sensor . cut the old bracket across the large hole replicating the bracket you cut off the daewoo sensor.Image put a 1.5mm washer onto the daewoo sensor and fit into original location useing the original cut down bracket you may have to clean the sensor location hole with a file or sandpaper . fit the socket end of the connector to the original wiring solder and heat shrink and you are done.Image
brianK
Post by brianK » Sat Mar 26, 2022 1:13 pm
More pictures for abs sensor Image[/img]
Post by Doone » Sat Mar 26, 2022 4:15 pm
Thanks very much for this 'briank' . :) We've added it to the FAQ.
viewtopic.php?t=78338#p721865
TheLongRoad
Post by TheLongRoad » Sat Mar 26, 2022 6:19 pm
Thanks, excellent share. 👍
willow2u
Post by willow2u » Thu Mar 31, 2022 9:15 pm
I invented the mod ages ago
Post by Doone » Fri Apr 01, 2022 3:54 pm
Thanks for the reminder. 🙂🙂 I've added yours to the FAQ too.
Bongolian
Post by Bongolian » Sat Jul 26, 2025 11:49 am
I’m going to replace both my front ABS sensors as the warning light appeared and they’re showing as faulty on the blink test, codes 11 and 12.
Any updates on suitable replacements.?
Scanning the tinterweb I’ve seen a couple that might be useable alternatives to the Daewoo suggested.
The ones I saw that may work include a Ford Ranger part, and also a replacement of only the sensor itself.
Obviously there’ll be some re-wiring involved whichever I get.
Just wondering if anyone had done theirs lately and had success with any other sensors.??
Bongolian
Post by Bongolian » Mon Jul 28, 2025 2:29 pm
These are significantly cheaper and come with all brackets required..
Bongolian
Post by Bongolian » Mon Jul 28, 2025 2:33 pm
Alternatively, without brackets but with no need to mess with any wiring, these look suitable too.
Bongolian
Post by Bongolian » Mon Jul 28, 2025 2:34 pm
Any Bongoers out there used either, or the supplier.?
