I purchased a renovation kit when I saw them on offer.
The kit I purchased was called "Holts Car Headlight Restoration kit" and cost £9.74 including delivery.
The kit consisted of:
A drill adapter with gives a 75mm velcro surface to attach the sanding discs / sponge
8 sanding discs (800grit, 1000grit, 1500grit, 3000grit)
A polishing sponge
Abrasive polish
Sealant
2 x cleaning cloths
Most of it is cheap easy to find bits, the sealant and the polish are the only bits of any real value I guess.
Easy process, of starting with the roughest discs and sounding the plastic lens down, then moving up until finally using the 3000 grit. At this point it is slightly hazy but the swirly scratches from the first discs have now gone. The abrasive polish is then used to make it nice and clear again. Finally the Sealant is used to give a final shine and to seal the plastic from further UV damage.
I presume it is supposed to be enough stuff to do 2 lights. I wore out the first 800grit disc and had to use the second. The other discs I just used one.
The sponge detached from it's backing when I was just finishing the abrasive polish, perhaps I applied a bit too much pressure?
There was loads of polish for the job and loads of sealant although it does say to redo the sealant periodically.
The result - I was very happy with the final result, the once yellowish headlight was now clearer than the good one, this left me with a slight predicament as I didn't have enough stuff to completely do the other headlight. I decided to just use the abrasive polish by hand and then use the sealant which did an acceptable job given that it was nowhere near as bad.
I've attached a picture showing before and after. The before picture doesn't really capture how bad the offside headlight was but I think you can tell the difference.
