Symptoms: 1 Sometimes i get a judder when pulling away from standstill or when i've stopped at lights and pulled away again.
2 A couple of times when i am moving in slow traffic and go to speed up it trys to rev high (i dont let it) so i release the throttle and accelerate away without issue(never happens twice in the same go)
3 Sometimes when its changing between 1st and 2nd, it takes a second or 2, then changes with a jolt ( like its jumping into the 2nd gear.
These symptoms are a bit random but the judder happens more frequently on hils, up and down.
Could this be a selector issue between 1st and 2nd and if so what is most likely to be the fault.
Again it doesnt happen all the time, less often than not.
Oil level is spot on and its new with the filter cleaned when i did the oil. Tends to happen more when the gearbox is cold.
If someone knows of simmilar or same symptoms i would greatly appreciate any input
Thanks in advance. Kev
