Front Fog/Driving lights 2002 Aero kit
Has anyone found a replacement for the above round lights inset into lower AERO kit bumper?
Mine has been smashed and can't find any reference to similar via forum search
thanks in advance
Simon
V6 2002 tintop
thanks in advance
Simon
V6 2002 tintop
Re: Front Fog/Driving lights 2002 Aero kit
There is a post on the site with a member who had sourced a replacement unit via eBay. I cannot find the post in question, so have a hunt as the details are on here.
Found it: https://igmaynard.co.uk/bongo/forum/vie ... ay#p697991
As for cleaning the lenses as the post mentions they get fogged with age, I found Meguiars plastic headlight restorer works a treat on those and the main lights.
Great thanks i'll have a look-missed that when did my search
Mazda 323 front fogs work perfect, all you need to do is swap the cable because the plug is different,which is also very east to do, i know this as i have had to do it twice cos of that damn M6 and its road works , make sure and get the black one tho as the silver is a later model and will not fit
https://www.ebay.co.uk/itm/MAZDA-323-98 ... SwmNlZZfyg and https://www.ebay.co.uk/itm/MAZDA-323-98 ... Sw-0xYW~-7,
much cheaper than bongo ones too.
Bongology, the study of all things bong. The bongologist.
You can also get replacement lenses too
https://www.ebay.co.uk/itm/MAZDA-323-PR ... xy9dVTj4Hw and https://www.ebay.co.uk/itm/MAZDA-323-PR ... xy9dVTj4Gq from lithuania, but be warned, taking the lense off can be difficult and you may split the unit
Hope this helps
Hope this helps
Also the lens restorer wont work as the lenses are glass, but white viniger will do the trick
Hi thanks for the replies
Mine are round not the rectangular like those- I found these which turned out to be identical to those fitted...
https://rover.ebay.com/rover/0/0/0?mpre ... 2677906497
ah slightly newer model then, hope it goes well mate
