1996 2.5td 4x4 - Restoration Project
Re: Cardiff - Starting & coolant loss problems
Post by Bob » Thu Jan 04, 2018 5:56 pm
If it's not been bled properly it will be troublesome. :(
Post by Bob » Thu Jan 04, 2018 7:29 pm
Very frustrating indeed. :(
Good luck, hope you manage to find said problem. [-o<
cutlass
Post by cutlass » Thu Jan 04, 2018 10:49 pm
do you have rear heater? check that! need to go under car at right in the middle and look... do you dont have antifreeze in exhaust sistem? lean your hand at smoke and than lick... if it will have "sugar tast" - head is crushd... :cry:
Baldrick
Post by Baldrick » Fri Jan 05, 2018 2:08 pm
I have had the same problem loosing around the same amount of coolant , today i found the leak under the rear heater where it connects to the vertical pipe going up inside to the rear heater. Luckily i havent been anywhere in it just starting it up now and then .After squeezing between the garden fence , slithering underneath and banging my head numerous times i can not tell if its coming from where it is joined just above the clip or from further up inside the van. Does anybody know the best way to take the panel off where the rear fan is before i start ordering hoses. To top things off my Main battery has died on me :( any ideas on decent batteries anyone?
I am new on here but have had my bongo for 5 years and just an unsociable sod so any help would be appreciated.
Post by g8dhe » Fri Jan 05, 2018 3:31 pm
The new battery requirement would be handled by a Bosch S4 335 or 028 or several other 3 digit final number! Several on-line vendors or your local automotive will normally have them in stock
Baldrick
Post by Baldrick » Fri Jan 05, 2018 3:41 pm
Thanks i will do a bit of googling for prices :D
cutlass
Post by cutlass » Fri Jan 05, 2018 4:16 pm
for next - you must use rear radiator from mazda 626(89-91 year), kia pikanto (need cut and replace tube) Image or from lada priora or hyndai accent (by HALLA) Image Image
Post by Bob » Sat Jan 06, 2018 9:43 pm
Well done. 8)
cutlass
Post by cutlass » Sat Jan 06, 2018 9:50 pm
:D =D> for next -on my car now i use silicon pipe from MOFE - excelent! https://ru.aliexpress.com/w/wholesale-s ... +hoses&g=y
haydn callow
Post by haydn callow » Mon Jan 08, 2018 5:05 pm
What your last post tells me is....either your not bleeding it properly with the funnel method or you are getting air sucked into the system. An hour on the funnel is more than enough, you spent 2 hours.
http://www.coolantalarm.co.uk
Also BMW Clocks
Post by g8dhe » Mon Jan 08, 2018 5:09 pm
When the Bongo was designed the same de-gassing tank was used for all three engines, however, they ONLY difference was that on the 2l engine they opened up the third hole in the tank and fitted the extra hose to make it self bleeding. Now differences on the production line cost a lot of money - there had to be a reason why they only fitted the extra bits on the 2l engine and not all of them - for some reason self bleeding doesn't work on the diesel or V6, hence my reasoning that they didn't fit the extra pipe.....
haydn callow
Post by haydn callow » Mon Jan 08, 2018 5:37 pm
Defo would not recommend putting steel seal in...
Also BMW Clocks
cutlass
Post by cutlass » Mon Jan 08, 2018 6:08 pm
check head again :(
teenmal
Post by teenmal » Mon Jan 08, 2018 6:25 pm
cutlass wrote: Mon Jan 08, 2018 6:08 pm check head again :(
Ditto
haydn callow
Post by haydn callow » Mon Jan 08, 2018 6:29 pm
If the head was goosed I would expect the system to pressurise and the tank overflow pipe to start spitting out coolant.
Also BMW Clocks
