Pinouts for CL fob reciever please
Re: Pinouts for CL fob reciever please
Post by g8dhe » Wed Dec 13, 2017 4:45 pm
The lock solenoids for all the other doors use a reversing connection, rather than a pulsed connection. I would assume that the original drivers door lock option used the same method, so you would need to select that option in the new system and no doubt also run a pair of wires into the door using the same route as the drivers door loom from the control unit unless it is door mounted.
Post by g8dhe » Wed Dec 13, 2017 5:17 pm
The connection for the door solenoids is ONLY in the door, the wiring loom only carries in power and the other door functions, that is why the receiver is mounted inside the door, it picks up power but then directly connects to the solenoid with no need to run the solenoid wires back via the loom.
