Post
								by rustyp » Sat Aug 19, 2017 11:39 am
			Hi Mike, in my previous Bongo I had rusty water stains in the cab from spurting boiling water!!!
Firstly I can say in practice it works, a couple days after filling and bleeding I was on a drive and thought I would try the valve, the engine was hot, I heard a tiny bubbly "burp" there was a little bit of air still trapped in the system probably worked its way up from the rear heater matrix, without this system it would probably been the case that this little bit of air wouldn't have been purged.
The valve/pipe stays cold but when turned for bleeding the pipe gets hot due to the coolant flow (I will cover in pipe lagging).
Because the header tank is at the highest point, my easy bleed pipe slopes up towards the header tank then that is where the air travels to. Also the air in the engine is hot and expands (high pressure) and migrates to the cooler (low pressure) area being the header tank.
I have considered putting together a kit consisting of a length of 10mm coolant hose, a valve, a T-piece, jubilee clips, grommets and pipe lagging with detailed instructions including where to drill the 2 holes etc. (one in metal, one in plastic). It would be quite low cost.
