Downloadable bleeding instructions any where on site pls
Is there a printout of the bleeding process any where pls
And maybe one for how to drop roof with a roof failure
I have looked
Many thanks
I have looked
Many thanks
Re: Downloadable bleeding instructions any where on site pls
Roof drop is here from the manual http://www.g8dhe.net/bongo_images/How%2 ... 20roof.pdf
Bleeding: http://www.igmaynard.co.uk/bongo/member ... oolant.pdf
Roof troubleshooting (which references the manual in Geoff's link): http://www.igmaynard.co.uk/bongo/member ... ts/aft.pdf
Spot on with the roof one that's what I'm after
Might be lending me bongo to a mate for a few weeks
Carnt open the others
Many thanks
Many thanks
Can a youtube video be saved to a phone/tablet/stick for off line viewing?
Chris with BertieB
You can choose to "view later" depends on capability of browser/app device your using.
- Muzorewa
Systems vary and also depending on which browser you're using, but with Real Player installed you can normally download YouTube videos - as the video is playing move the cursor over the playing video and a tab should pop up in the top RH corner to download. Failing that, download DVDVideoSoft (for free) and you can download, cut and convert to any format you want.
Gasy, your mate needs a degree in phonology and then he can take bleeding videos (that doesn't sound good does it
) wherever he goes!
Chris with BertieB
I want a print out so it can be in the glove box
If they have any problems
It's there for the garage to read in black and white
I'm sure a friendly member could email me the fact sheet
