HID Headlight motor.
- Rapidair65
I'm in the process of rustproofing our new Bongo. It's a 2004 model with adjustable HID headlights. The nearside adjuster appears to be intact but the offside has most of what appears to be a manual adjuster missing. Are the adjuster motors available separately? Sorry no pictures as I still haven't mas tered posting images yet!
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
- helen&tony
Re: HID Headlight motor.
Have you tried Bongospares to see if they are a separate entity?
Have you tried using the control on the dashboard to see if the motor is operational? The HID headlamps are pretty hard to come by and I would doubt you'd be able to just buy the motor on its own.
- Rapidair65
On further inspection it looks like the complete manual adjuster has disappeared. There is a blue plastic nut with teeth on its base which engages with similar teeth on the back of the motor. This blue nut is missing off the drivers side unit. The van passed the MOT so I assume the headlamp aim is Ok. I think leave well alone is the answer! Thank you to all for the replies.
