Knocking from rear suspension.
Titan1995
Post by Titan1995 » Fri Jul 10, 2015 7:36 am
My Bongo has developed a load knock from the rear.
Does not seem to be speed related and sounds like something broken maybe drag link, road spring or similar.
It becomes very loud at parking speed while turning left.
Recently replaced all the front end suspension and steering components I am assuming all is good up front and the noise is not travelling.
I have not had chance to get the Bongo up into the air yet but plan to do so today for inspection.
So looking for any advise on any common problems to look for in this area.
Re: Knocking from rear suspension.
Post by mikeonb4c » Fri Jul 10, 2015 8:20 am
I'm trying to remember if a broken u-clamp in my rear torque rod caused something like this when one broke on mine. Worth checking in case.
Titan1995
Post by Titan1995 » Fri Jul 10, 2015 8:46 am
mikeonb4c wrote:I'm trying to remember if a broken u-clamp in my rear torque rod caused something like this when one broke on mine. Worth checking in case.
Thanks for that could well be something like that...won't know until I get it up into the air later.
Post by mikeonb4c » Fri Jul 10, 2015 12:44 pm
Too early in the morning for me - I meant anti-roll bar of course, and the clamp that holds it in place #-o
roosmith
Post by roosmith » Fri Jul 10, 2015 1:05 pm
My anti roll bar went as well last year, nice cheap, easy fix!
marionw
Post by marionw » Fri Jul 10, 2015 2:09 pm
I'm having the same problem with mine at the moment.
Booked in to have it diagnosed and fixed next Thursday.
Titan1995
Post by Titan1995 » Fri Jul 10, 2015 3:45 pm
Yep it was a broken anti roll bar clamp.
The bush has disappeared.
I will replace the bushes & clamps along with the drag links.
Phew a cheap repair at last.
mikeWalsall
Post by mikeWalsall » Fri Jul 10, 2015 4:02 pm
Maybe not so easy if a bolt as sheared off ..!!
Post by mikeonb4c » Fri Jul 10, 2015 4:05 pm
Titan1995 wrote:Yep it was a broken anti roll bar clamp.
Excellent. Quick cheap result. You should soon be enjoying a smooooth ride :-)
P.S. Stop being so pessimistic Mike :lol: But seriously, with luck it will be like mine - fatigue in the u-clamp metal. But Mike makes a good point: get some penetrating oil/WD40 on the bolts now and leave it for a day or so before tackling. Did I read somewhere that if necessary, getting some heat on the bolts (from a blowtorch) can help if they're seized?
Titan1995
Post by Titan1995 » Fri Jul 10, 2015 4:12 pm
mikeWalsall wrote:Maybe not so easy if a bolt as sheared off ..!!
No the fixed bolts are still there.
Should not prove too difficult after all the other work I have completed on this vehicle.
Titan1995
Post by Titan1995 » Fri Jul 17, 2015 3:46 pm
Nice and easy to do...replaced my rear pads while I was there.
Love my impact gun though.
Replaced both rear anti roll bar bushes and brackets along with the associated drag links.
Like a new vehicle now.
Post by mikeonb4c » Fri Jul 17, 2015 4:07 pm
Titan1995 wrote:Nice and easy to do...replaced my rear pads while I was there.
I know. I think of all the old cars that I thought were a crappy ride. Maybe they too just needed new droplinks and bushes. Mine haven't been done for years. think I might schedule to do them as I bet the ride will feel a lot better after.
Impact gun sounds interesting. What's that then?
