Where have people been getting their resistors form for modifying the Temp Guage??
I am in France, so can't walk into my local Maplins, and at 14€ for a rocker switch I'm not buying components localy!
Thanks Tom
Temp guage mod Resistor?
www.idriskis.com eco friendly skis
Re: Temp guage mod Rseistor?
Mine were off eBay £1.20 for 5. Would post you one, but you're in France!
- the1andonly
- Tribal Elder
You probably all ready know this
"International Delivery"
Online orders can be shipped to anywhere in the UK, Channel Islands or the Republic of Ireland, unfortunately we can not ship to locations other than these at present.
so ordering online from maplins is also not an option
Try
http://www.conrad.fr/
http://www.conrad.fr/ce/fr/product/1056 ... archDetail
gives 100ohm 3w surface mount resistor @ 2.o5 euro
better french and searching may get what you want
German site in english also have 10ohm .39 euro
http://www.conrad.com/ce/en/Search.html ... 100+ohm+3w
Try
You don't want Surface Mount components for this purpose, you need wire ended, thru hole mounting resistors.
- the1andonly
- Tribal Elder
Agree Geoff
perhaps should have said "need"
a though hole component would be easiest, If push comes to shove to use with SMD tinned copper wire affix to terminal (crimp solder) and solder to pads, check clearance to housing
- BongoBongo123
Re: Temp guage mod Resistor?
As a matter of interest is this an easy job or a fiddly one ? i.e. complete dash removal?
An improvement over the originals slow response would be great.
They call me light foot.
It's not complex, but does involve removing the displays and the actual thermo display from the unit, this needs some delicate work as over tighting the screws can damage the meter connections.
Pm me
I will send you one
I will send you one
I would walk 500 miles.
99 Tinted tintop
Supplied and looked after by Bongospares
99 Tinted tintop
