Annoying bleep!!
bongoroy63
Annoying bleep!!
Post by bongoroy63 » Sat Jun 07, 2014 8:54 pm
I know this has been discussed before but can't find it. As much as I love my van I have had enough of the beeping when I have the key in the ignition and the door open. I have had the panel to the right of my right leg off today in the hope of disconnecting the beeper. However, there are a number of connectors and wires in there! Can anyone tell me which one I have to disconnect please?
I can, I do, I did.
Re: Annoying bleep!!
Post by g8dhe » Sat Jun 07, 2014 9:06 pm
You just need to unclip this connector;
Under the cowl below the steering wheel, with care you don't need to remove the cowling.
bongoroy63
Post by bongoroy63 » Sat Jun 07, 2014 9:20 pm
OK thanks, but I was told by a couple of people it was behind the trim on the right hand side of the drivers footwell. Is it the same on all Bongos? Mines a 97 model.
I can, I do, I did.
Post by g8dhe » Sat Jun 07, 2014 9:28 pm
No the Sound Warning System module is down there, many people cut the wires, for the Key-in-lock signal all you need do is separate the connector shown and the door beep will stop, Headlights, AFT and reversing beeps won't be affected.
bongoroy63
Post by bongoroy63 » Sat Jun 07, 2014 10:23 pm
OK thanks I'll give it a go and report back.
I can, I do, I did.
bongoroy63
Post by bongoroy63 » Sun Jun 08, 2014 8:15 pm
SORTED!!!! Silence is truly golden. Thanks for the advice.
I can, I do, I did.
Mrs Muppet
Post by Mrs Muppet » Sun Jun 08, 2014 10:05 pm
Thank. We did this too. What a difference it makes!
Post by g8dhe » Sun Jun 08, 2014 10:18 pm
Its much nicer than cutting the wires or sticking a screwdriver thru the buzzer that others have done, and if you want, it can always be put back to standard!
