TM 2 temp gauge help please,
Hi again everyone,I'm in the process of fitting a TM2 temp gauge,its all wired in and after a little set-back is working,my problem now is I haven't got a clue which is the best way to route the sensor cable into the engine bay,can anyone who has fitted one give me some pointers......many thanks Paul
Re: TM 2 temp gauge help please,
Under the driver seat hatch there is a bit of rubber you can cut out on the top edge were seat seal rest on
Lay cable their and then gaffa tape over top
Job done
Job done
There's a big rubber grommet just in front of the gear selector under the cubby hole. You can cut a hole in that and feed some convoluted trunking or a piece of hose pipe thru which you can feed wires. All the wiring for my 3 coolant alarms, cruise control and LPG is routed this way.
Here's a photo. The metal pieces are behind the plastic panels under the centre cubby hole. You can see the black trunking poking out where it passes thru.
Thanks, that would be great......cheers
You have 3 coolant alarms?Simon Jones wrote: All the wiring for my 3 coolant alarms, cruise control and LPG is routed this way.
- haydn callow
My last Bongo..V6... Had a total of 6 coolant and temp alarms.
1. Standard Low Coolant Alarm
2. High Coolant Alarm
3. TM-2 Tempreture Alarm ( under evaluation for a V6 )
4/5.The CUBE Twin temp alarm ( monitoring each cylinder head )
6. 'I Alert'coolant temp alarm with sensor within the top hose.
Admittedly some of these were so customers could be shown what was available.
Now available is :-
Tm-2 temp alarm
Combination of both the above.
TM-4 single and twin sensor temp alarm
TM-1 temp alarm
Go to website below for full details....this is now under the control of my daughter Jo
Now available is :-
Tm-2 temp alarm
TM-1 temp alarm
YupSpencer54 wrote:You have 3 coolant alarms?Simon Jones wrote: All the wiring for my 3 coolant alarms, cruise control and LPG is routed this way.
2newbies wrote:Hi again everyone,I'm in the process of fitting a TM2 temp gauge,its all wired in and after a little set-back is working,my problem now is I haven't got a clue which is the best way to route the sensor cable into the engine bay,can anyone who has fitted one give me some pointers......many thanks Paul
Job done
Cheers guys ordered my TM2 today and i now know where to route the sensor
Big thanks to Haydn's daughter Jo for sorting specific delivery day & time for me.
Blimey...
I knew coolant and the Bongo have had there differences - but TM2 and 4, wow that must light up like an 80's stack system
