Flashing Hold
jimpearceuk
Flashing Hold
Post by jimpearceuk » Tue Feb 18, 2014 8:40 pm
HI All - my hold light has started flashing, initially it would go when a reset and now its on even with just the ignition. I have a Willington split charge but seems to be working.
Any ideas how I can check its not the split charge 100% I have disconnected the positive to the leisure battery only and that didnt solve it.
My mechanic friend has checked the signal from the gearbox sensors, mine has 2 as its a 200 model???
Also does anyone know hoe we can read fault codes from the gearbox? there is no marking on my plug to know whats what?
Any info gratefully received.
Thanks Jim
Ahead
Re: Flashing Hold
Post by Ahead » Tue Feb 18, 2014 10:00 pm
I had a flashing hold light but coupled with an erratic speedo (jumping from 0mph all the way around and back)
Removing the kph to mph chip cured it. Worth checking.
Simon Jones
Re: Flashing Hold
Post by Simon Jones » Wed Feb 19, 2014 8:45 am
Factsheet for diagnosis: http://www.igmaynard.co.uk/bongo/member ... dlight.pdf
Does your speedo work ok? I wouldn't have thought there would be any connection with the split charge unless it stopped working at the same time.
Gearbox speed sensor location varies depending on engine and gearbox type. This is one example:
jimmo62
Re: Flashing Hold
Post by jimmo62 » Wed Feb 19, 2014 10:00 am
Instructions on reading diagnostics are here (free) http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
jimpearceuk
Re: Flashing Hold
Post by jimpearceuk » Fri Feb 21, 2014 1:52 pm
Thanks for the replies. Problem solved by my garage. CAE in Wokingham Berks
With a little help from Dunnings (thanks to them) he was able to read the fault code, it came out as a shift solenoid, part ordered and changed and hey prosto she is better than ever!
Chuffed
Thanks Jim
ginger colin
Re: Flashing Hold
Post by ginger colin » Sat Feb 22, 2014 9:16 pm
Hi. Was it the solonoid in the box i noticed ava leisure sell box solonids for about £160. In the description it mention hold flashing and overdrive probs.
jimpearceuk
Re: Flashing Hold
Post by jimpearceuk » Mon Mar 03, 2014 11:33 pm
ginger colin wrote:Hi. Was it the solonoid in the box i noticed ava leisure sell box solonids for about £160. In the description it mention hold flashing and overdrive probs.
Hi Colin - yes thats the one.
The cost was the solenoids and autobox fluid etc
Supper cool again now :)
Jim
