AFT not opening!
Jenwren
AFT not opening!
Post by Jenwren » Sat Aug 17, 2013 11:39 am
Any advice would be greatly received. Have tried all the usual, i.e. handbreak, level ground, parking etc...
Re: AFT not opening!
Post by Muzorewa » Sat Aug 17, 2013 11:57 am
Whereabouts are you, a local Bongonaught may be able to assist :wink:
Post by g8dhe » Sat Aug 17, 2013 12:33 pm
Are you getting any Beeping once the Raise switch is pressed ?
If not then is the Handbrake light on on the Dashboard ? (To raise the AFT the light must be on).
Is there any noise, even a click, from the motors at the rear of the AFT ?
hijimhere
Post by hijimhere » Sat Aug 17, 2013 1:41 pm
Handbrake on + engine running + In P for Park + foot on foot brake - just try this select down then up.
Post by Bob » Sat Aug 17, 2013 2:07 pm
Welcome aboard.
I've been known to press the wrong side of the switch. :oops:
hijimhere
Post by hijimhere » Tue Aug 20, 2013 12:22 pm
Did you resolve???
