Engine getting hot
jessica1
- Junior Bongonaut
Engine getting hot
Hi there I am new to this and having a bongo.we drive the bongo for about 3mins and the heat coming from the middle of the car is hot.its not overing heating at all don't think we are loosening water.does it get hot that quick.or is there a problem starting to happen
Any replys would be great
Dan
Dan
- mikexgough
Re: Engine getting hot
Assuming you are a new Bongo owner.... You are sitting on top of the engine hence the heat....obviously my disclaimer here is that it isn't getting over hot due to coolant or other issues
The centre console area will get pretty warm but it normally takes a little while before you notice it.
jessica1
- Junior Bongonaut
It takes about 2 to 3 mins and you can smell the heat if you know what I mean.
Hi my cover gets warm in about 10 mins but its a dull warmth not a searing heat. Mines a 2.5 diesel.
Check that the seats are correctly locked down, and that there isn't any insulation missing.
Under the seats, both sides, there are three sprung latches which lock the seats in position and seal the engine bay from the Cab. If they have been left undone or the rubber seals and insulation have been damaged that might be the cause of your problem!
New Forest Terrier
I find the metal latches work loose on mine and need a regular pushing back into shape with the rubber tent peg hammer. When they work loose I notice fumes more than heat but it is a V6, so different.
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
Lift the covers with engine running and try and see if anything obvious could be causing it. It shouldn't be getting hot only minutes after start up. Agree with others about the latches though. Keep us posted.
- mister munkey
One consistent problem with mine has been trying to get some heat in.
What is the temp reading after 10 mins running - on the dash gauge? Does it sit happily at the 12 o'clock position?
Could there be a heatshield missing from the exhaust manifold? The manifold is the only thing that would normally produce a lot of heat in a very short time so I would check that.
check the no1 exhaust manifold isnt snapped.
http://www.igmaynard.co.uk/bongo/forum/ ... ud#p418217.
and that the rubber round the underside edge of the seat flaps hasnt rolled, so letting the heat through to the cabin.
- The Great Pretender
Lots of conjecture, wouldn't it be better to know what engine is fitted?
To infinity and beyond
Indeed. Hence my hint to lift the covers. It doesn't so much matter what engine it is, as what it does, since the latter is the reason for having the former.The Great Pretender wrote:Lots of conjecture, wouldn't it be better to know what engine is fitted?
Yrs
The Riddler
Searching jessica1's older posts about an oil leak, its a 2 litre petrol....
jessica1
- Junior Bongonaut
Hi all thanks for the replys have taken bongo back to the garage I got it from have said about the heat he said you will get heat in the middle.i now know what the smell is it had a oil leak as well after standing and arguing with the dealer for ten mins.got a call today saying the camshaft oil seal was leaking so they have repaired that.its still under warranty till June.so hopping if any thing else goes wrong it will before the end of June.
But not sure if its normal for the camshaft oil seal to go like that I have had a few cars in my time but not a bongo so it may be a comment thing with bongos.picking bongo up Monday.just find some car dealers hard to deal with when things do go wrong even thou its under warranty.
Dan
Dan
