submersible or not?
Moderator: Doone
- Apprentice Bongonaut
submersible or not?
The onboard sink water tap on my Wellhouse Engineering side conversion Bongo has stopped working - I have had the Bongo since November (when it was working) but am only just preparing it for the first expedeition - the thing is I don't know if I should look for a pump hidden behind panelling,or is it a submersible pump? - I have checked all relevant fuses and wiring which appear 'live',so I am beginning to suspect the pump - as anyone any ideas please?
Re: submersible or not?
This is a water tank from a Wellhouse side conversion, so if yours is the same, you will have an inline pump. Simple solution is to follow the pipework back from the base of the tank.
Thanks Simon - I'll check it out asap - Graham
