Dash illumination
Dash illumination
I have a nice green glow with lights on from my rev counter fuel and temp gauges. However the speedo seems to be lit by a clear bulb and looks odd! The Speedo has the outer MPH and inner KPH. Is this normal? I would prefer the nice green glow if it's a bulb thing.
- Tribal Elder
Re: Dash illumination
Mine is the same, (white light on speedo) I had a Jal conversion done, and when I asked Phil at Jal about it he said the bulb may have been changed when they did work on the speedo, I have learned to live with it but I know what you mean, it looks odd. Is your's a Jal conversion by any chance or has someone changed the bulb ?
"Today's rain is tomorrow's Whisky"
- mikeWalsall
Mine as green illumination .. well ..that is aside from the stupid white MPH conversion dial .. which is confusing for instant daytime reading .. and worse at a night, as the outer KPH illuminates .. and not the 'stuck on' white MPH inner part of the dial ..
Thanks Jim & Mike - I don't know the history but the speedo is the normal black with white numbers. Can't tell if it is a sticker or if its a a complete speedo? Is there a way to tell if it is a JAL conversion? I have bought another instrument panel, the reason escapes me,
looking at the rear there are 4 types of bulbs. 1. Small black plastic (clear bulb) 2. Small grey plastic (clear bulb) 3. Large black plastic (large clear bulb) 4 Large green plastic (Large green bulb). All of the plastic casings are marked "V - 2 Toshiba". They remind me of the old days where replacing dash light bulb would be necessary from time to time - simply twist & remove. Google show plenty of bulb sellers - far to many to trawl through.
You can see the green bulbs here:
Great shot - the spare cluster I have has two green and two clear large bulbs behind the speedo.
The green bulbs are basically clear ones with a coloured "sheath" over them to give a green hue....
When the bulb gets changed, the "bulb condom"
should have been replaced back onto the new bulb..?
With the heat off the filament bulb the green sheath can stick so it may have torn when that bulb was replaced...?
I replaced mine with red leds when one of the backlight bulbs went... You can pull what is basically a "capless wedge" bulb out of those twist in holders...?
Just found out the hard way the the blind switches have a small bulb that can be replace easily - anyone got any spare?
- mikeWalsall
Are they this type as they are easily sourced from car shops ..
no, they aren't for installing in instrument cluster or function switches
the blind switches from the back have a small brown rubber like rectangle - if you pull this from the switch it is about an inch long mostly shrouded with the rubber but has a tiny bulb on the end - its very small and definitely a bulb - I bought a replacement switch from a breaker but the bulb in that was gone........................
Funny enough i'm tinkering with my front blind switch.... Bulb gone too!
Its more like the 3rd one on the right in the top row of bulbs in the link you posted earlier... http://www.toshiba-lighting.com/servlet ... RFK4KFL1LF
It's more like the tall brown one on 3rd from left on the first page
