Temperature Gauge
rickanne
Temperature Gauge
Post by rickanne » Mon Dec 10, 2012 9:01 pm
Hello
I'm new to this site, please can anyone help. My problem is my temperature gauge has stopped working, this has just happened, we have had the van since August and all has worked lovely until now! The heater works and it doesn't appear to be overheating. Any ideas anyone? Thanks, Rick
Re: Temperature Gauge
Post by Northern Bongolow » Mon Dec 10, 2012 10:07 pm
if its a diesel lift the drivers seat up then look at the front end of the engine. look for a single wire coming over the front end of the rocker cover, it sounds like its come off the top of the sender or the sender top has broken off. clean it up carefully and put it back on.
the gauge itself doesnt usually give much trouble, unless someones wired something in behind the dash like a speedo chip etc.
rickanne
Post by rickanne » Mon Dec 10, 2012 10:17 pm
Thanks for your reply, the van is a V6 Petrol, shall I follow the same procedure as you suggest for this.
Post by Northern Bongolow » Mon Dec 10, 2012 10:21 pm
simon or geoff will know better where the sender is on a v6 but as i recall its right at the front of the engine on the top of the stat housing, and you have to reach under to get to it. this makes it even more likely to be damaged by water etc, but the guys will put you right.
the gauge is the same.
rickanne
Post by rickanne » Mon Dec 10, 2012 10:30 pm
Thanks very much for your help, I will check this out. Rick
Simon Jones
Post by Simon Jones » Mon Dec 10, 2012 10:59 pm
At the top front of the engine is an alloy manifold that feed the two heads. If you follow the bleed pipe under the passengers seat inspection hatch, it the part the pipe comes from. You will see a wire that goes to the brass coloured sensor. If you squeeze and wiggle the connector it should disconnect from the sensor. Give lug a little clean up with some fine sandpaper to remove any oxidisation. Reconnect it and see how it goes.
Post by g8dhe » Mon Dec 10, 2012 11:24 pm
If it helps here are the mechanical diagrams the sensor itself is 18-840C http://lushprojects.com/bongopartsmk2/c ... no=.html#9
and the manifold it fits in is 15-17Z http://lushprojects.com/bongopartsmk2/c ... 2of02.html
rickanne
Post by rickanne » Tue Dec 11, 2012 7:01 pm
Thanks for all your help. Rick.
Getcarter
Post by Getcarter » Wed Dec 12, 2012 8:14 am
Sorry to jump in but I have the same on my 2 litre petrol. Which side should I be looking in? Driver or passenger?
Thanks!
V6 Tintop with LPG
Post by g8dhe » Wed Dec 12, 2012 10:24 am
On the 2 l see 18-840 here http://lushprojects.com/bongopartsmk2/c ... no=.html#9
and that part appears, to me, to be on the drivers side 10-180 http://lushprojects.com/bongopartsmk2/c ... mgno=.html
