I recently completed a trip round france successfully with no issues.
After about 800 miles and a few tanks of french fuel the Bongo started up in a morning quite lumpy with juddering and white smoke being emitted from the exhaust for 10 seconds. After that it was fine.
Ever since on a cold start it does the same. I thought it was the fuel and so put some diesel injector cleaner in but as yet it still does it.
Also the front heaters work really well until you go on a long journey and then they sometimes fluctuate between hot and cold after a while. Are these problems linked in some way??
If anyone can give me some advice on either problem I would be grateful.
One Mechanically useless Bongonaut !!
White smoke on start up
- Junior Bongonaut
Re: White smoke on start up
How's your coolant level? If it is not dropping at all, then my money is on the glow plugs.
- Junior Bongonaut
Coolant level seems fine.
Ill check again though.
I vote for glow plugs as well
Also, I've moved your post to Techie, as I don't think you'll get much joy in the Camping Equipment section
- loruntz135
- Junior Bongonaut
White smoke is, I believe, unburnt fuel.... suggests, as it rights itself so quickly, that a glow plug is
broked..... I hope that's all it is as we have an identical symptom!!
Rich
Rich
The great thing about multitasking is that several things can go wrong at once
