Engine noise + smoke
HELP!!!!! I was reversing the Bongo when a tap tap tapping noise came from the engine, and smoke came from the exhaust, any ideas, please
Re: Engine noise + smoke
Hi what engine does the vehicle have....
Hi Teenmal, its a 1997 2.5 Turbo Diesel.
Hi It will depend on how the engine is running Now,could be a faulty injector pump,broken cam shaft,faulty valve gear,piston/rings,turbo,etc etc.
How is it running Now.
PS do you use vegetable oil?
Cheers.
Cheers.
Hi, turned it over, still has heavy tapping noise and clouds of smoke.
No, we don't use veggie oil, just diesel.
Hi,is it smoke or steam.Not advisable to run for any length of time.
Cheers.
Cheers.
How long have you had the car? Any known history of faults? Is the oil level OK? Coolant level OK? What does the engine look like when you lift the covers - any sign of anything amiss? What colour is the clouds of smoke? etc. etc.
We bought the van in February, it went in for a service and mot last week, the garage changed the filters and did an
oil change, they checked the coolant and garage said that it was fine., Oh and it does appear to be smoke. we do know that the last owner had cooling system overhaul in August last year, am going to have another look over the engine know see if I can see anything, Thanks for your replies.
What colour smoke (white/steamy, black etc.). Coolant system overhaul sounds interesting - I hope it was done properly. Did they have to have just a replacement head gasket, or a new head as well. Was the old head pressure tested, was the engine block flatted before mating with new head/gasket. And what had caused the problem. Overheat, due to loss of coolant? or water pump failure? gunged up old radiator? etc. Was the work done by a garage that knows Bongos? Answers to these questions would be useful.Roadtrip wrote:We bought the van in February, it went in for a service and mot last week, the garage changed the filters and did an
do a compression test, check the timing, or whip the rocker cover off and check the camshaft.
What's the oil level like in the engine...?
Do you know what the work was that was done by the previous owner? Did they have the head replaced? There have been a couple instances on here where recon heads have been fitted and subsequently had a valve drop as some of the clearances where not checked. Hope it's nothing too serious
David Edwards
my guess would be dropped a valve as it sounds exactly the same as mine did.
Here's a thread that may help: http://www.igmaynard.co.uk/bongo/forum/ ... Head+valve
