Side door not opening
Sometimes, but not all, I can be sitting in the back and when I go to get out the door doesn't open. It's as if it's locked as the handle doesn't fell engaged to anything. I've tried locking/unlocking with the remote but to no avail. It opens from the outside fine though.
Any ideas?
Any ideas?
Re: Side door not opening
Hit it very hard indeed from the inside, about 10 inches below the handle. Not a gentle tap but a really hefty whack.
There's quite a lot on here about it, it's not uncommon, so if hitting it doesn't work do a search for something more technical.
Alison
Have you checked that the child lock isn't on? If it is, the door can only be opened from the outside.
Why didn't I suggest that before I suggested extreme violence?francophile1947 wrote:Have you checked that the child lock isn't on? If it is, the door can only be opened from the outside.
Alison
- PisceanJoy
Child lock Happens to me sporadically Its easy to knock into the on position inadvertently
Strip of duct tape over the switch is a quick cure. Not the most clever position to fit a switch specialy when the only way out is climbing between the front seats.
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
Yep child lock. Was always wondering what that switch did.
Mine's blocked with a lump of Blu-tackNew Forest Terrier wrote:Strip of duct tape over the switch is a quick cure. Not the most clever position to fit a switch specialy when the only way out is climbing between the front seats.
Alisons is blocked with a baseball bat sized dent
Alison
- nicstrike
- Tribal Elder
i wasn't going to say anything but.........
