Right, sounds like we have the same motor Bob.. Mines a 95.bikerbob wrote:Yes thats exactly how my sensor probes react, ambient temperature then climb as coolant heats up but on reaching temps of +75C and above erratic temp readings occur.
Is the metal heater hose the long one that runs along the top of the head and is about 25mm Dia above the head of
the rubber hose metal spigot, if so can fit 2nd sensor probe on there. The vehicle is a 2.5TD year 1997/98.
I fitted the first probe to part 15-179, on the stub.. http://lushprojects.com/bongopartsmk2/c ... mgno=.html Which is shielded from the front by the cam belt casing/enclosure..
The other probe.. Is the heater outlet spigot, drivers side... (Just above the rad fan sensor.)
Check the link on the second post down on this topic about leaks..! http://www.igmaynard.co.uk/bongo/forum/ ... +hose+leak
Here's a rough drawing... (Its a tight space & i used a metal zip tie holding it in place on the spigot.)
First chance i get, i will do a photo shoot of my own...
