Where do I start to check for the fault.Thanks in advance.
Central Locking.
				eckerB
Central Locking.
The central locking has suddenly stopped working,will it be the fob or a fuse blown??????
Re: Central Locking.
does it work if you pull/push the knob? if not then its usually the wiring between the door/body
Julian
						Julian
Hi Ecker....most likely problem is wiring between drivers door and door pillar....I am sure that our more technical members will be queuing up with advice.....
You have come to the right place...
Alan
Sod off Julian.....you type faster than me....
Alan
Alan...still plodding on....!
						- missfixit70
Could be the battery in the fob, or could be the battery supplying the CL is low.
You didn't mention if the CL system was part of an alarm...!
Before you start pulling too much apart...!?
Then.. Power supply to the remote receiver itself.. Could be one of those pesky glass fuses in the holder come lose/not making contact in the clips..? (I only prefer blades!)
Could the aerial on the receiver be bared off at the end & touching part of the bodywork/chassis? That will/could affect reception..?
Wires running from the receiver to the locking actuator.. (Normally two wires with bullet connectors.) With door slamming they can come uncoupled...?!!
I'm assuming it's an after market system??...
All the way round with the key...321Away wrote:does it work if you pull/push the knob? if not then its usually the wiring between the door/body
Julian
Check that one!missfixit70 wrote:Could be the battery in the fob, or could be the battery supplying the CL is low.
				eckerB
Tried the door knob to see if the CL worked and it didn`t.Tried the fob and it worked twice then nothing!I will start by getting the fob checked and go from there,thanks for the help guys.Regards Eric.
P.S. Don`t think it`s an aftermarket thing,also it`s not attached or anything to an alarm.
				eckerB
The C-Locking has been working again for the last 24hrs!All I have done is to hook-up our caravan,unhitched the c-van,c-locking still working?????
Almost certainly a break in the wiring by the drivers door, its just intermittent connections by the sound of it.  The trouble is the insulation may not even be broken and you may have to feel for break in each wire along it length where its stressed by the bending and clip/tie.
				eckerB
Thanks again Geoff,next time the CL stops working I`ll get on it.Do you have an idea of the colour of the wire which is likely to be the culprit please or is it going to be hit and miss when looking for the break?Thanks in advance for everyones help.Eric.
Well there are three wires which handle the CL are Blue/Red (+12v), White/Black and Yellow/Red, but I would check each wire in the loom as you will be annoyed to find that the windows stop in a week or two's time!  Run each wire between thumbnail and and first finger if you fill a "notch" then be suspicious the chances are some of the wires will have broken inside the insulation even if the insulation hasn't broken.
				eckerB
Thanks again Geoff,will get at it asap.
