V6 '99 - Digital or Analogue Odo ?
flossie
Post by flossie » Fri Sep 24, 2010 1:46 pm
Hi does anyone know which this is likely to have ? Can't tell from the pics the importer has mailed me
Liz
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
Re: V6 '99 - Digital or Analogue Odo ?
Post by Northern Bongolow » Fri Sep 24, 2010 2:40 pm
haydn should be along soooooooon :lol:
haydn callow
Post by haydn callow » Fri Sep 24, 2010 4:06 pm
Analogue !! on mine
http://www.coolantalarm.co.uk
Also BMW Clocks
scanner
Post by scanner » Fri Sep 24, 2010 6:08 pm
Surely ALL odometers are digital - as they only show digits. :?
Does Flossie mean cable driven or electrically driven?
If so - I'm fairly certain all Bongo Speedos and Odometers are electric as that is how the conversion chips work.
haydn callow
Post by haydn callow » Fri Sep 24, 2010 6:36 pm
I took it to mean...Numbers revolving...or....LED type display
Also BMW Clocks
2sticks
Post by 2sticks » Sat Sep 25, 2010 10:29 am
The speedo head is driven directly from the gearbox frequency sensor.
With standard wheels and tyres, f = 100 Hz = 70 KPH. (linear).
All conversions, ie. counters for odometers and digital to analog for the
speedo needle are done electronically within the speedo head.
scanner
Post by scanner » Sat Sep 25, 2010 12:28 pm
haydn callow wrote:I took it to mean...Numbers revolving...or....LED type display
If that's all then I don't see what difference it makes, unless you want to "clock" it when what appears to be thought of as "digital" is reputedly much easier if you have the right computer etc.
flossie
Post by flossie » Sat Sep 25, 2010 11:45 pm
This came from one of the importers fact sheets ... I forgot they are general Jap importers as I'm so Bongo focussed right now ... Sorry !! :oops:
Liz
