rear diff/transmission
hermanator
Post by hermanator » Sat Apr 03, 2010 7:06 am
van has 45mm lowering springs fitted and has a rear camper conversion. I have a fiammia bike rack and when loaded [ 2 bikes & a fiammia carry bag] i get a noise from the rear of van when i'm doing 65-70mph. When i go back on the gas it goes.It dosen't do it all the time. When i'm not using the bike rack it's fine, no noise. could the cause be the lowering springs putting extra strain on the transmission?
maxheadroom
Re: rear diff/transmission
Post by maxheadroom » Sat Apr 03, 2010 8:04 am
I am sure there reports of lowered one having trouble with drive shafts, due to the new angle.
BDC will know :D
Keep the Faith
You've Been Bongod
Post by You've Been Bongod » Sat Apr 03, 2010 9:04 am
didnt bdc have to change his cv joints every year because of this ??
321Away
Post by 321Away » Sat Apr 03, 2010 9:57 am
err states noise is from the rear, no cv's?! have you checked diff levels,as could be slack in the rear diff thats taken up under power, its a full on mission to rip it all out to inspect, but lots of places rebuild them if thats the case.
Julian
Post by mikeonb4c » Sat Apr 03, 2010 10:15 am
321Away wrote:err states noise is from the rear, no cv's?!
I think YBB knows that but was just wandering off thread (as some of us do a lot :oops: ) to answer Max's comment on BDCs 4WD.
What's your view Justin on the wisdom/risks of lowering suspension and then using a Bongo for normal (i.e. well loaded) campervan duties? I wonder if its a bit close to trying to have your cake and eat it? :roll:
PS - oh and welcome hermanator 8)
dandywarhol
Post by dandywarhol » Sat Apr 03, 2010 8:11 pm
With the suspenders lowered so much and the back laden you could be so close to the bump stops that you're hearing a "crash" when they bottom out, accelerating could make the rear squat slightly to clear the noise............................
