fans and sensors
fans and sensors
Sorry if covered before, but ive read how to check the scavanger fan if its working or not by unplugging the sensor, run the engine and they should come on. does the front radiator fans also come on by doing this?
So if i unplug this sensor and run the engine and nothing happens, what do i do to fix this, and get them all running again?
Thanks in advance
Thanks in advance
- missfixit70
Re: fans and sensors
For the rad fans it is the 2 wire sensor further back & lower down above the outet hose to the heater which is above the starter motor, unplugging it with the engine running should bring the fan/s on, also switching on the a/c should bring on the fans. This doesn't test whether the sensor is working obviously.
If the fans don't come on, check fuses & connections, I think there is a factsheet on repairing rad fans.
cheers Kirsty i'll take a look
Kirsty had a look in the members area and didnt see thar fact sheet on the fans,missfixit70 wrote:For the rad fans it is the 2 wire sensor further back & lower down above the outet hose to the heater which is above the starter motor, unplugging it with the engine running should bring the fan/s on, also switching on the a/c should bring on the fans. This doesn't test whether the sensor is working obviously.
I dont think mine are coming on at all but i will have to wait til tomorrow to check properly.
Anyone know the link for this please
Ron
Is THIS ONE what you're looking for? (I couldn't see any others).
Cheers Doone, were was this then? cant find it in the members fact sheets i haveDoone wrote:Is THIS ONE what you're looking for? (I couldn't see any others).
Your fan sensor might be at fault then Ron... make sure you replace that lead as you'll have no glowplugs in the morning otherwise!
- missfixit70
That link is not for the rad fans, it's for the ventillation fans. It must have been a post on t'forum I saw re the rad fan repair, can't find it as yet.
Falcoron, when you put your aircon on with the engine running does the rad fan come on?
If you are relying on your rad fan to cool your engine during normal use (especially in this cold weather) I suspect you have other problems rather than the fan itself, ie rad blocked, stat not opening properly. personally I wouldn't drive it until you get this sorted.
They are a bit of a trawl to read thorugh, but these threads should help you understand a bit better what should be going on with your cooling system
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=35902
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=36433
- missfixit70
Found the link I was looking for,
unfortunately the links are dead, may be worth contacting Jon 41, unless anyone happened to save a copy of the info? It certainly should have been a factsheet.
From this thread - http://www.igmaynard.co.uk/bongo/forum/ ... fan+repairJon 41 wrote:As promised a very detailed description of problem and cure in either a word document or adobe pdf document. Hope this helps other members![]()
http://www.webtech1.co.uk/strip.doc
http://www.webtech1.co.uk/strip.pdf
Thanks guy's
Im gonna redo a dump,flush,dump, refill clean water, dump,new stat, refill with coolant, bleed and check all the fans and sensors. hopefully i can get this sorted once and for all. Unfortunatly i cant afford a new rad at the mo but i am gonna get one before the season starts just to be sure. So by then i should be well up on the bleed procedure.
Ste, I have replied to your PM mate, thanks a million, top bloke
Thanks again Kirsty,
I'll get a read at this later this evening.
