As an owner of a lowered bongo, i have read this thread with much interest... (twice in some cases to fully understand)
However... When on original wheels and suspension, i noticed a tendency of excessive tyre wear on the insides of the rear tyres.. Before i had the vehicle tracked, i fitted 18" alloy wheels, and shortly after some 50mm lowering springs, not only did this make the steering much more direct,understeer seemed decidedly reduced!
The handling imprioved also, and the tyre wear evened out, i haven't yet felt the need to have the vehicle properly tracked up (in fact, i've never had the tracking done on the bongo) As there appears to be no pulling to either side, except a slight tendency to follow the camber of the road to the gutter, but that happens on every car should the camber be great enough. The only downside to the lowering of the vehicle appears to be a compromised ride (but i prefer it firm anyway) reduced ground clearance (it's a good job i'm really careful) The bongo eats through front CV boots, (because of the acute angle of driveshaft to CV joint, especially when the wheels are on full lock). Otherwise, no probs!
(though now i'm REALLY reluctant to ever get the tracking done in case it buggers it all up!)
