Rubber roof seal - where ?
Is it possible to but new, e.g. brand new, rubber seals for AFT roof ? mine leeks at one point, appears to be decaying there and really could do with replacing.
tyia.
tyia.
Hi im Simon
- You've Been Bongod
Re: Rubber roof seal - where ?
thats a good question which i cannot answer
but i bet someone will be along shortly to rectify the answer
there has got to be somewhere that does these because i have seen a showgun with a aft
i wonder if you could get something like a door seal if you could get one long enough ?????
JustKampers http://www.justkampers.com/search2?keyw ... ubmit.y=11 sell various roof seals. I haven't got around to checking for compatibility properly yet, but from memory the "general purpose seal" (JK13096) looked as if it might do the job.
see i said someone will be along soon with all the info you need
- mister munkey
Have a dig around here.
http://www.lushprojects.com/bongopartsmk2/
Probably get the at least the part number.
- helen&tony
As far as I can see, it's not an unusual seal . There used to be a dealer in rubber car components like seals around Edgware. They had a huge catalogue supplying to the classic car world in the 60s/70s, and last I heard , they were still around. Try asking around the car restorers in the classic car world....Richardsons for MGs for instance....the seal on an MG Maggot hard top was not dis-similar....I bought mine for a new hard-top....I seem to remember....from the Edgware chap.
Cheaper than Mazda, I'll wager
- helen&tony
Here you are....I knew my memory wouldn't let me down
....try sending them a 1/2 inch offcut from your old seal to match it, and temporarily stick a bit of duct tape over the gap where you remove it, to stop the water getting in.
http://www.rubbertrim.co.uk/
Don't forget to order more than you need, as fitting the trim round curves and corners uses FAR MORE than you imagine, and ask for any joiner section where the two ends meet
Good Luck, and let us know how thee fares
An excellent post. It would be good to hear the outcome and to have info added to a factsheet or similar as tthis one is bound to come up again with our ageing Bongo fleet
