power not like it used to be
parawaiting
Re: power not like it used to be
Post by parawaiting » Tue Jan 20, 2009 7:21 pm
my bongo always went like a rocket on diesel or veg oil before :D
another symptom for those contributing is there is also a noise like when you have the air blower full on that seems to be coming from around he passenger dash, when you try to accelarate hard
cheers for the info so far
dandywarhol
Post by dandywarhol » Tue Jan 20, 2009 7:25 pm
I haven't removed a Bongo pump but done others - the pump mounting is slotted for adjustment isn't it? With a tolerance of 0.05mm allowed I'd be hard pushed to see that accuracy with my eye on the marks :?
PS - just read your post para - is there a turbo pipe loose or disconnected??
scanner
Post by scanner » Tue Jan 20, 2009 8:43 pm
parawaiting wrote:my bongo always went like a rocket on diesel or veg oil before :D
That sounds like the turbo boost leaking - check you haven't loosened a hose and are dumping all your boost to the open air.
A Non-turbo Bongo would go very much like your description of how yours goes.
parawaiting
Post by parawaiting » Wed Jan 21, 2009 3:11 pm
cheers for all the ideas, gues i'm going to have a busy day under the bonnet :D
scanner
Post by scanner » Wed Jan 21, 2009 4:21 pm
Another thought did you make sure you replaced the turbo boost compensation tube that connects the turbo to the injector pump so that the pump knows to increase fuelling when the turbo pressure starts to build up.
Without that the engine only gets more air - not the more air AND fuel that it needs.
parawaiting
Post by parawaiting » Mon Jan 26, 2009 3:28 pm
thanks for all the ideas, i had a look today and found the large bore rubber pipe which connects to the exhaust manifold had completely come off which explains the lack of turbo. took it for a quick spin and all seems back to normal, watch out boy racers :mrgreen:
Post by missfixit70 » Mon Jan 26, 2009 3:44 pm
=D> Nice one, simple solutions are always the best :D
Post by mikeonb4c » Mon Jan 26, 2009 4:54 pm
parawaiting wrote:thanks for all the ideas, i had a look today and found the large bore rubber pipe which connects to the exhaust manifold had completely come off which explains the lack of turbo. took it for a quick spin and all seems back to normal, watch out boy racers :mrgreen:
Result - excellent =D>
scanner
Post by scanner » Mon Jan 26, 2009 5:22 pm
Errr - Inlet manifold?... :?
parawaiting
Post by parawaiting » Mon Jan 26, 2009 5:37 pm
:oops: i wish there was a pictorial glossary for us mechanical numpties
:oops: :oops: :oops: :oops: :oops:
parawaiting
Post by parawaiting » Mon Jan 26, 2009 5:49 pm
just had a look a lush projects which seems to be what i need lol
