sounds like a plan has just come together
Coolant- Opposite to usual problem
- Eat Aunt
- Location: Bongoing since 2005 in the Portsmouth area :)
Re: Coolant- Opposite to usual problem
Thanks again folks
20 YEARS BONGO-ING
Black Std 2WD AFT
Now 2001 WHITE V6 Tintop ... 253,000 Km
Black Std 2WD AFT
- westonwarrior
Warning
If you go down the route of warming up the engine before doing this be very careful when taking off the filler cap
- daveblueozzie
good point, i forget its not always obvious to everyone to slowly release the cap off the expansion tank.westonwarrior wrote:Warning
Lost without my Bongo.
spout
Are you sure all these alternative methods for getting the anti freeze in are not more hassle than just draining out, refilling properly and rebleeding?
- daveblueozzie
easily done in ten to fifteen mins for the method i described,spout wrote:Are you sure all these alternative methods for getting the anti freeze in are not more hassle than just draining out, refilling properly and rebleeding?
how long to drain ,fill and bleed properly and then bleed and then bleed.
- haydn callow
Think you have a good point there "sprout" see my first reply !!
DBO... Iv'e never had to rebleed or top up after a refill/bleed. At least you will know it's all in there and properly mixed...swings/roundabouts I suppose....each to his own....!!
- daveblueozzie
Agree, Haydn swings and roundabouts, pros and cons for both methods, i suppose it depends on how confident you are to drain and bleed the system.haydn callow wrote:Think you have a good point there "sprout" see my first reply !!
The way i described works and is fairly idiot proof (which is perfect for me
Ive had my coolant completely changed twice and radiator flushed as well (both set's of silicon hoses) and both times no problem with air being trapped, but always had to top up the next day.
The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
For the uninitiated, the H/P method reduces the chances of airlocks by purging the air as the coolant is added in the first place.
This is the safest way to strengthen the coolant in my opinion, as neat antifreeze is being replaced by the exiting water simultaneously.
Nah mean?
Nah mean?
Now, how about extending this debate. If we are gong to do that, then is there any reason why you couldn't do an effective coolant change using the same method? I'm getting tempted.bigdaddycain wrote:The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
Whose 'KK' by the way. He lives right next to 'MM' on the keyboard but it could be coincidence [Edited - Nope its KK for Kawasaki Kid - doh!]
Talking of which (says he wandering off thread again), Clive James on BBC R4 today at 08:45 (try listen again) gave a hoot of a talk for those of us getting clumsy on the keyboard, keeping pens that don't work in old coffee mugs etc.
Last night I emailed my mate Daymo to tell him I'd just taken my son Will's mates back after the birthday party to their homes in Knutsford. I'm always mistyping that word to spell something rude. Last night (woops) I did it again. This time I just left it be
- missfixit70
Coolant change using that method is basically the "Hosepipe method" Mike
KK - Kawasaki Kid
- missfixit70
Other way round you mean Ste? Exiting water is being replaced by the neat coolantbigdaddycain wrote:The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
Nah mean?
BDC... Big dopey ****
(chap)
DOH!... Yep...missfixit70 wrote:Other way round you mean Ste? Exiting water is being replaced by the neat coolantbigdaddycain wrote:The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
Nah mean?
- missfixit70
Long night?
No thanks luv... i've just had one!missfixit70 wrote:Long night?
