Door mirror motors or not?
samuel
Post by samuel » Mon Sep 22, 2008 7:10 pm
Am I right in saying that although I have the door mirror switch with the folding door mirror switch, it doesn't necessarily follow that there are actually motors fitted to operate the folding function?
It has never worked anyway but I was just wondering.
"Living the Dream"
M 80NGD
Re: Door mirror motors or not?
Post by M 80NGD » Mon Sep 22, 2008 7:16 pm
One of mine does work and one doesn't. It doesn't mean the motors are missing,probably just replaced with a non electric item. :shock: This happens a lot in Japan,apparently!! :D
My Names Bond......Lee Bond!!
Post by francophile1947 » Mon Sep 22, 2008 7:45 pm
If they didn't have folding mirrors, they didn't have the switch (just the mirror adjusting part). maybe motors bust or removed.
the janner vanner
Post by the janner vanner » Mon Sep 22, 2008 8:15 pm
check your wireing between the door and body. I heard a horror story at the southwest bash of a door catching fire. One of my door mirrors stopped working and when i opened the plastic cover protecting the wires i found two wires were bare, thus causing the fuse to blow. It could have been worse,
Dave
The Janner Vanner
samuel
Post by samuel » Mon Sep 22, 2008 9:33 pm
Thanks for the advice guys.
They haven't worked since i have owned her and that's nearly four years!! If the wires are bare or prone to wearing through then i think i need to check that part of the loom and avoid a possible fire. :oops:
"Living the Dream"
Post by missfixit70 » Mon Sep 22, 2008 9:50 pm
I've got one just stopped working too, must get around to sorting it :roll:
Post by bigdaddycain » Tue Sep 23, 2008 2:41 am
samuel wrote:Am I right in saying that although I have the door mirror switch with the folding door mirror switch, it doesn't necessarily follow that there are actually motors fitted to operate the folding function?
You can see if the motors are there without removing the mirror lens,just peer through the gap in the back of the mirror, if you spot an aluminium dome shape just behind the mirror glass, then yes, you have motors fitted inside the mirrors.
:wink:
samuel
Post by samuel » Tue Sep 23, 2008 8:28 am
Thanks BDC
That was my next question.
Tim
"Living the Dream"
Post by missfixit70 » Thu Sep 25, 2008 12:48 pm
Good news, mine fixed & at no cost. :D
Checked voltage was getting to the mirror (after removing door panel) - it was, so took it off (two bolts under the outer lower cover & one inside the door), prised the mirror off ( pull gently on the OUTER lower corner of the mirror & it pops off quite easily) unscrewed the mechanism & withdrew it from the casing ( 3 screws inside the casing, one underneath & the 3 holding the casing to the mounting). All the cogs etc were intact, so applied 12v direct across the motor, nothing happened, tried it t'other way, still nothing. Concluded motor was duff. but had a fiddle about to see if the rotation of the motor was actually doing anything, tried 12v again & it worked 8) tried it a couple of times, all ok, reconnected it, worked as it should - boxed back up, job's a good'un for now [-o< :D
It was quite easy to get to really, cut the door plastic rather than peel it back to save getting the black sticky stuff from hell everywhere. The two green wires on my passenger door are the ones feeding the mirror open/close function if anyone's checking the door looom for damage (mine was ok)
the janner vanner
Post by the janner vanner » Thu Sep 25, 2008 5:30 pm
you now have peace of mind, Kirsty, i'm glad you got it sorted
The Janner Vanner
Post by mikeonb4c » Thu Sep 25, 2008 6:45 pm
Good result - you lucky person. =D>
samuel
Post by samuel » Thu Sep 25, 2008 10:02 pm
I'll do what you did Kirsty. Godd advice.
Thanks Tim
"Living the Dream"
Post by missfixit70 » Thu Sep 25, 2008 10:38 pm
samuel wrote:I'll do what you did Kirsty. Godd advice.
Thanks Tim
I know I'm good :wink: but not that good :lol:
Stick some sound deadening on the door panel (adhesive bitumen flashing as a cheaper alternative) while you're in there and/or a bit of waxoil, making sure not to block the drain holes in the bottom of the door.
Fingers crossed it's an easy (lucky?) fix [-o<
Post by bigdaddycain » Fri Sep 26, 2008 12:19 pm
Thanks Tim
:lol: :lol: :lol:
Post by missfixit70 » Mon Sep 29, 2008 8:39 am
Well mine stopped working again on saturday :( , but worked again yesterday :D , so I think I maybe need to source a new motor.
I can't recall whether anyone found a compatible one, it looked a reasonably standard sized unit, I've got the measurements written down at home, have to dig them out when I get back from sunny France 8)
