Cubby in front of gearshift.
How easy is it to remove? It would be handy to get at wiring behind. If it's not easy, I'll just get at it by removing glovebox, but it is quite a stretch from there.
- daveblueozzie
Re: Cubby in front of gearshift.
dont actually think you can remove the cubby ,its part of the dash. ive had a look and its not slotted in like the radio dins, it seems part of the moulding.
Lost without my Bongo.
Mine definitely doesn't detach from the dash, that being said it's quite easy to reach from the removed glove box. I added a twin socket into mine by drilling through from there.
Good luck.
Good luck.
- missfixit70
By removing the glove box & little side panels either side below the cubby (prise the middle of the popper gently, pull the whole popper out, then it just unclips) you should have access to pretty much anything you need to
I wired my TM2 to the fuse board without cubby removal take off the wheel housing and loads of room
Sparky
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
Thanks to everyone who replied, and especially to Kirsty. I'll have to try that when I get a chance. Thanks again.
Colin
Colin
- missfixit70
Depending on what wiring you need to get at, you may want to take out the clocks too. It's so nice to have a vehicle that you can get at whatever you need too with the minimum of dismantling.
