Pressure V Temperature
daveblueozzie
Re: Pressure V Temperature
Post by daveblueozzie » Tue May 13, 2008 12:00 am
if you have a mason alarm fitted, then the temp guage will move about a lot ,even going into the red zone, the normal position for temp guage without a mason alarm is about 11 oclock ,with a mason it is about 2 oclock and this moves when the engine is being pushed or at standstill.
the setting for the mason is a tad under the 5 on the mason dial (thats what i have it set at) it does the odd bleep now and again if pushing the engine. uphill mainly.
Lost without my Bongo.
haydn callow
Post by haydn callow » Tue May 13, 2008 8:36 am
I belive the Mason alarm is doing what it is supposed to do. Makes the temp gauge more sensitive. You didn't worry before you fitted it. You (I think) said you had it set at 4.5. Others I have spoken to have it even higher.
When pushed the bottom hose does get hot (stat opens)
Normal driving it stays cool (stat closed)
I think your system is working o.k.
I think !!!!!!
I think.......
http://www.coolantalarm.co.uk
Also BMW Clocks
dandywarhol
Post by dandywarhol » Tue May 13, 2008 12:25 pm
Good tip - assuming the air con works.
Grahame at work
Post by Grahame at work » Tue May 13, 2008 1:07 pm
Lizard,
The bottom hose will eventually reach nearly the same temperature as the top hose if you let it idle and wait a while after pulling up following a 'hard' run. This could be around 70C but usually around 60C.
The ECU turns the fans on using the same relay as the A/C so that is a good way of checking the fans work but you can also check the ECU part of the loop by disconnecting the sensor (above the starter motor) and the fans should come on.
The fans come on when the coolant temperature in the head is about 100C which is about 70/75% of the scale of the Mason modified gauge.
As others have said - if your fans work I think it is runing normally.
Regards Grahame
dandywarhol
Post by dandywarhol » Tue May 13, 2008 6:42 pm
If I remember the fans won't come on if the a/c isn't fully charged with gas. So the a/c compressor dictates if the fans come on or not.
lizard
Post by lizard » Tue May 13, 2008 7:37 pm
Thanks guys, you have filled me with confidence. It all appears to be as you say. :D :D :D :D
The rad fans work with the air con switched on. :D :D :D :D
One last question boys, how hot does it have to be to have the scavanger fan working :?:
Thanks again
F Zappa
dandywarhol
Post by dandywarhol » Tue May 13, 2008 7:54 pm
According to the manual the scavenger fan comes on if:
The engine bay temp is below -27 deg.C and the coolant temp is over 90 (automatics)
The engine bay temp is below -30 and the coolant is over 90 for manual vehicles
The engine bay temp is over 180 deg (auto)
The engine bay temp is over 171 for manuals
Aethelric
Post by Aethelric » Tue May 13, 2008 7:56 pm
lizard wrote:Thanks guys, you have filled me with confidence. It all appears to be as you say. :D :D :D :D
Thanks again
Hi Lizard, you know the fans will work :D , but best to follow Grahames advice to make sure they are getting switched on by the ECU.
Dave
Aethelric
Post by Aethelric » Tue May 13, 2008 8:00 pm
dandywarhol wrote:According to the manual the scavenger fan comes on if:
Wow. So it actually works to heat the bay when it's really brass monkeys as well. I guess it won't happen to much in this country though.
Dave
lizard
Post by lizard » Tue May 13, 2008 9:35 pm
Hi Lizard, you know the fans will work , but best to follow Grahames advice to make sure they are getting switched on by the ECU.
Dave
Yes, Cheers again, I will. :)
It's got to get ********* hot then for the scavanger :!: :shock:
F Zappa
Post by mikeonb4c » Tue May 13, 2008 10:46 pm
Dave
Not with an over-ride switch fitted. Tee hee :lol: :lol: :lol:
lizard
Post by lizard » Wed May 14, 2008 12:01 am
mikeonb4c wrote:
Dave
Yes I have read your post :) , might be worth a go eh, Mike
F Zappa
Distilled Waters Run Deep
Post by Distilled Waters Run Deep » Thu May 15, 2008 5:49 am
After I get the new radiator fitted, my local garage says to remove thermostat altogether permanently -he's apparently done this to a lot of Bongos & says that then they never overheat.
Hard to believe Mazda could be so wrong as to fit unnecessary kit?
I know a bit about air-cooled motorbike engines, but all this plumbing has me scratching my bald patch.
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
Veg_Ian
Post by Veg_Ian » Thu May 15, 2008 7:07 am
and also means that it takes longer to warm up and use more fuel in the process. So your average mpg now is?
haydn callow
Post by haydn callow » Thu May 15, 2008 8:22 am
I don't think your garage knows much about Bongo's. If all else is well the stat should be in situ. The vehicle will never get to a good working temp with no stat.
Also BMW Clocks
