Hi All
Much to my disappointment I have discovered a water leak into the drivers side footwell the carpet is wet the bongo has been parked up for about a week and we have had some pretty wet weather here has anyone else had a similar problem if so were was the water getting in.
Thanks Gary AKA Bongopatrol
Interior water leak
- Tribal Elder
Check mine every week - when I first got the van the drain pipe had a family of spiders living in it.
It pays to keep it clear as the front blower motor lives under the drain and doesn`t take too kindly to getting wet.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
- The Great Pretender
In my wallet....
Bongopatrol? Was your window definitely closed properly?
I'd have a check of the seal around the door, or, if you look under the dashboard (drivers side) Try looking at the mounting point bung for the clutch pedal,its a white elongated diamond shaped plastic bung/cap, that leads straight into the under bonnet area. it may be worth checking its sitting flush against the firewall....
