leisure batteries
- helen&tony
leisure batteries
I'm looking to buy a replacement leisure battery over here, and I suspect that they may be a bit hard to locate, however, marine batteries may be a different kettle of fish , so to speak! Are marine batteries for starting outboards, running cabin lights etc. manufactured as "deep cycle" batteries in the same way as leisure batteries, with tougher plates?
Thanks in anticipation of help
- helen&tony
leisure batteries
Hi John
That's more or less what I feared....I'll just have to punt around, and take our young friend, who speaks perfect English, and hope, somewhere along the line, that we can order one.....camping is a bit basic over here, but a lot of fun!!!
Not sure about that one - as a lot of leisure batteries are marketed as marine / leisure, but i would agree that a marine battery is mostly used to start a boat and be charged whilst running just like a normal starter battery. They normally sit for a long time between starts however, but not sure if this is really deep cycle
- helen&tony
leisure batteries
Hi Madmile
I've read that leisure batteries have re-inforced plates to prevent warping when charging from an almost "flat" state. It is always stated as unwise to fully discharge a leisure battery, and keep it in such a state for extended periods, as irreversible chemical changes render it impossible to recharge it, but, as I say ,deeply discharging it and recharging it will not cause such harm as it would to a normal battery. I had been told that "deep cycle" batteries are commonly used in boats, but as John says, mainly as accessory power, and as such, are "leisure" batteries rather than a marine equivalent....shame , really, as I just need a simple replacement that may seem hard to find.
If it's any help, the batteries I use on my boat are ordinary car-type batteries for engine starting, and deep-cycle leisure batteries for running everything else. I am sure they were marketed as marine/leisure batteries when I bought them, so I would have thought they were quite suitable for use as Bongo leisure batteries.
I have small diesel inboard engines on my boat, but friends who have outboard motors normally use car batteries to start them, certainly not marine batteries.
Don't quote me, but i'm sure the Bosche 110 a/h l/b i bought from costco was also sub-headed as being for marine use too...
I know that costco isn't much use to you in bulgaria Helen&tony, but if we can ascertain that leisure batteries fall into the same catagory as marine batteries, that may help you in your search.
- helen&tony
leisure batteries
Hi all
Yes, that's more or less what I wanted to establish....if the batteries are classed Marine/ leisure, then I will probably be able to pop into a chandlers over here...there's no shortage of boats. Before next camping season, I've a few upgrades to do to the battery area, and chuck the old LB in favour of a new one, and rewire some of the services onto the LB.
Many thanks for the help, folks,
