Cruise control
- Tribal Elder
I found that the stub holding the rubber cap has a ring about 5mm from the tip which stops the cap sliding off. If you use pliers to pull the tip of the rubber, it should come off relatively easily. If your eyes are watering or you have crossed your legs, you have a dirty mind!scanner wrote:The hardest bit was reaching and removing the cap over the vacuum take off stub on the pipe at the front of the engine - I'm surprised nobody started a thread complaining about the bad language.
In the end I had to use a Stanley knife to cut it off and that took at least 6 attempts working totally blind.
But the end result is absolutely and totally worth it, I cannot think of any better improvement to a Bongo for £85.
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
- Tribal Elder
I think Torchwoods device is superb and if I had the faintest idea how to make one I would give it a go. The only thing that might worry some (not me) is that an insurance company (or loss adjustor) wouldn't like it. His is certainly the best for economy as well. I used to use a cold start knob in exactley the same way and it worked well.
I use my cruise in every 20/30/40/50 speed limit I drive through and it must have saved me a ticket by now. I can spend more time looking ahead and forget the speedo. It is a Godsend in temporary roadwork zones.
If you pick your speed to be 1 mph under the average you can use cruise on quite buisy roads and get places in more or less the same time. I find the Bongo a bit cramped for me and the chance to wiggle my right foot around is the difference between being comfortable or uncomfortable, for that alone it is worth it. I probably spend a good 50% of my driving time cruised up. If you spend your life worrying about leaving a space in front that someone can sneak into then you might only use it 20%.
I also find it more relaxing to let people bungee forwards and backwards whilst I drift along in the middle. You need to drive differently to get the most out of it but I think it's worth it. If you just use it for town limits and wiggling your toes it's still worth it.
After a lot and I mean A LOT of searching for somebody else I've found that the 99€ Cruise Controls are still available from Nimarks in Germany.
They aren't called MS-50 any more though.
Click for Link
Click for Link
Yes, they are the original folk who had them at 99 euro, and say they have plenty. They still called them the MS-50 when I contacted them last week. Nimarks at Nimarks.de works if you need to ask them to start a new auction.scanner wrote:After a lot and I mean A LOT of searching for somebody else I've found that the 99€ Cruise Controls are still available from Nimarks in Germany.
Click for Link
Almost there...
Finished fitting mine today - very much helped by Simon's docs and many useful comments here.scanner wrote:Finally finished it today and got it working properly after snipping the black loop that alters the sensitivity of the speed sensor.
At present, it tests out 100% statically, but is not kicking in when I try to use it on the move (tested up to 40mph so far, no time for open road tests yet).
I have sensitivity M and have not yet cut the black wire. Did others find it didn't kick in properly until that wire was cut?
Otherwise, I'm wondering if I got the right speed sensor wire - blue/white from the loom going to the central connector behind the instrument panel.
Pretty sure I didn't get that wrong but, because our speedos are not chipped (we have lots of kilothingymebobs over here and hardly any miles), I thought I'd better double check before cutting something!
You folks are all just amazing, by the way...
You HAVE to cut the black wire or the pulses are wrong for the sensor and it won't lock on.
I have the sensitivity set to low and find it takes up wonderfully smoothly don't use H or it will snap your neck.
If you want a quicker take up use M but even that can trigger kick down if you resume from a low speed and that rather negates the fuel saving ethos of fitting it.
