manual gearbox oil level
jimbo07
Post by jimbo07 » Sat Jul 28, 2007 7:16 pm
how much oil in the manual gearbox and where to check
brorabongo
Post by brorabongo » Sat Jul 28, 2007 7:31 pm
2.5 litre of pure long life gear oil SAE 75w-90.
As for where to check, you need to remove the filler plug and check it's just about level with the hole. :?
Hope thats of some use to you.
ボンゴの激怒 pictures
jimbo07
manual gear oil
Post by jimbo07 » Sat Jul 28, 2007 7:58 pm
thanks for your quick responce,but i have two filler plugs close together,on the left hand side,one is a torque plug and one isa square type
brorabongo
Post by brorabongo » Sat Jul 28, 2007 8:17 pm
From what I can see, there is a drain plug on the bottom plate on the square section (bottom face plate,with bolts around the edge), and just to the right there is another drain plug protruding at 90 degs to the first one mentioned, its the plug just above that, which is the filler plug .
Confused yet? :lol:
ボンゴの激怒 pictures
jimbo07
manual trans oil
Post by jimbo07 » Sun Jul 29, 2007 5:37 pm
thanks for your help,i think it is sorted know,cheers
DemonAV
Post by DemonAV » Fri Aug 03, 2007 9:09 am
It is here
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
