Dye Test for exhaust gases in the coolant system
patmckenna
Post by patmckenna » Sun Jul 15, 2007 4:10 pm
Hi Guys,
I need to clarify what exactly is involved in dye-testing the Bongo engine coolant system to detect the presence of exhaust gases - an indicator of cylinder head or head gasket problems.
My local garages seem uncertain of procedures. I need to know how it works so that I can find a competent garage who wont fob me off with a pressure test.
Thanks folks
Pat McKenna
waycar8
Post by waycar8 » Sun Jul 15, 2007 7:03 pm
i think what happens is the air that’s at the top of the haeder tank is drawn into a turkey baster-type device thats fitted with a valve of sometype, what passes through a dye that changes colour if theres exhaust gases present.
paul9
Post by paul9 » Mon Jul 16, 2007 12:47 am
it is this type of thing that is used to test for exhaust gases in coolant i think.
http://cgi.ebay.co.uk/COOLING-SYSTEM-CY ... dZViewItem
prb007
Post by prb007 » Mon Jul 16, 2007 12:11 pm
Thats' exactly what my mate used approx 1 month ago.
Discolours the dye on detection of CO gas.
Thought it was the gasket - white smoke on start-up
& using water, but turned out to be cracked & warped head!
600quid later - its' all sorted - hope yours is cheaper.
patmckenna
Post by patmckenna » Mon Jul 16, 2007 9:13 pm
Hi Waycar, Paul & prb007
Thanks for the info. Cheeky bugger wanted me to pay £50 at my local garage for him to do the test. With the help of Paul's post, bought the kit for £29. Thanks!
prb007: I'll post a detailed explanation of where I'm at with overheating issues when I resolve a couple of difficulties. It may make your hair curl.
Pat
Peg leg Pete
Post by Peg leg Pete » Mon Jul 16, 2007 9:15 pm
Pat have you not told the engine supplier about your problems-- you must have a warranty.
Image Pete
