Advise re, Head gasket replacement
Greetings, I have an oil leak on the drivers side of the engine , near the front, my local garage ( Birmingham ) are good but not familiar with Bongo's. They have looked at the problem and said the head gasket needs replaceing which will also require the head to be skimmed, but are unable to give me a price untill they have thought about it, I have Printed out the Head Gasket info from the club newsletters which I will give to them but can any one give me advice on the possible cost I should be looking at and/or any information which may help ?
Regards, Mike.
Regards, Mike.
I would get a second opinion, preferably from a mechanic who knows bongos. Surely if the head gasket is leaking there will be at least a few other symptoms of a failing head gasket -- exhaust gases in coolant, losing coolant, blue smoke from exhaust pipe, etc. Maybe the oil leak is coming from the valve cover gasket if it's leaking out over the front of the engine.
- dreamwarrioruk
our gasket is leaking, i would think that a lot of bongos with have some oil leaks to some extent. im not burning oil and wouldnt consider removing the head unless i get a seroius problem. about 180 for the gaskets and bolts and i think about half a day to strip off head diy, dont know how much a garage would charge but like franco said if it aint too bad leave it alone.
hi m&k
here is a copy of my bill
good luck in finding the problem
___________
simon
I'm bongoing mad! R U?
___________
simon
Last edited by bongoing-mad-simon on Sun Jul 08, 2007 6:47 pm, edited 1 time in total.
- haydn callow
- haydn callow
oil leak
Dear M & K
I too thought my head gasket was leaking, drivers side near the front top of the block etc.
My mechanic says it is the inlet manifold gasket, and I will have it replaced later this year.
I have been to Europe with it like this twice this year, and going again in two weeks, no problem.
I see others on the forum who have had the same leak.
Really need to get it checked out first.
Just a thought?
Regards
Tomsk[/url]
Just a thought?
Regards
Tomsk[/url]
Many thanks to you all for your advice and thoughts regarding my oil leak, there is plenty to think about, a presure test is a good start but if Simons bill is about the average i ceartainly will not be going down that road unless i have to.
Best Regards, Mike
Best Regards, Mike
Just had head & gasket changed.
Head.........300quid - eBay
Gasket set; eBay.....50quid
Press. teast 40 quid.
Labour 200 quid - my mate.
Total .....600-ish.
still got probs, though....
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=12931
Total .....600-ish.
