Hi Steve
No such thing as an ice bullet, as when propelled in a rifle/ pistol, bullets are designed to change shape in the area immediately preceding the rifling in an area known as the forcing cone, and the metal changes in order to engage the rifling more efficiently. Thus an ice bullet would shatter, being of a non-malleable material.
It might be possible to stretch the imagination oh...about a million miles , and fire a large ice ball in a big-diameter musket (non-rifled), using the "patched ball" technique used in smooth-bores, where a ball is wrapped in cloth often lubricated in a mixture of tallow and bees-wax . Again. it might even be possible to use a saboted* ice-bullet, but bear in mind that any attempt to load a piece of ice is going to involve a degree of handling, and unless "Secret Squirrel" the master assasin carries round a dewar flask of liquid nitrogen to dump the ice-bullet in for a quick per-firing chill, then a hand-grenade would provide a better job when fired from a grenade launcher...quite untraceable
Ah....where were we???...yes, ice can muck up a
pump rotor, and it could show that the engine concerned had been run without antifreeze...
* Sabot is the French word for Clog, and striking underpaid machine workers in the cloth trade in France many years ago would throw a clog in the works of the machines to stop them working...thus naffing up a machine by throwing a clog in , became known a "Sabotage"
It also refers to a separate casing round a bullet, designed to protect it in firing, and disintegrating upon exiting the barrel, thus allowing the bullet to travel unharmed along the barrel.
Such a protective case is designed to propel a smaller diameter bullet at colossal velocity, and travel further than it's mass would normally allow it to travel under non-saboted conditions
