New flooring
Re: New flooring
Hi Dave like it. Good choice of colour to go with your cupboard unit. Well done, smart job. Trish
- daveblueozzie
Re: New flooring
I must admit Trish the choice of colour and pattern was not my first choice originally.
I asked BDC to come with me to have a look, straight away i could tell, my original choice was not good.
Ste in his usual manner, said lets have a think about this for few minutes, his polite way of saying my choice was crap
We found the same door colour that i used in the kitchen unit and matched them side by side.
We both eventually decided on the lino that i now have in the bongo (well, Ste decided, I had no option really
Lost without my Bongo.
Re: New flooring
OY don't blame me!
I like how the floor "ramps" to the rear...
- 8etty 8ongo
- Tribal Elder
Re: New flooring
thinking i might tackle this 'little' job this week (maybe)
how did you make the floor ramp down at the back?. is that piece separate and then the gap just filled with sillicone or something. also, do i just need 1 sheet of ply which i think is 8' x 4' and should i get it cut in half at the timber merchants (into 2 of 4' x 4' pieces). still not decided whether to go for lino or carpet?
- daveblueozzie
Re: New flooring
The ramp is a separate piece that was shaped to fit, filled the gap with bathroom silicon i think then fitted gaffa tape over the joints.8etty 8ongo wrote:thinking i might tackle this 'little' job this week (maybe)![]()
As for the size of ply needed, i dont know if one 8'x 4' is enough, i didn't use that size, i went to a local pallet maker and he sells ply sheets 30 inches x 40 inches for 50 pence each and i bought £3 worth (6 sheets) and i used two layers glued and screwed together for strength, smaller sheets easier to cut and use inside the bongo.
Re: New flooring
One sheet of 8x4 is easily enough for flooring the bongo.
- 8etty 8ongo
- Tribal Elder
Re: New flooring
ok thanks, how did you shape it? i have a jigsaw (i think) which i have used beforedaveblueozzie wrote:The ramp is a separate piece that was shaped to fit, filled the gap with bathroom silicon i think then fitted gaffa tape over the joints.8etty 8ongo wrote:thinking i might tackle this 'little' job this week (maybe)![]()
also...if i do have to cut into the side panels, what should i use.
thanks
- 8etty 8ongo
- Tribal Elder
Re: New flooring
thanks, thought so but just wanted to checkDodgey wrote:One sheet of 8x4 is easily enough for flooring the bongo.
Re: New flooring
The Jigsaw is your friend. None of the "shaping" is tricky. My advice is to grab a large amount of cardboard and you can then, with scissors and tape, make a template for the "top"/"front"! half - to draw around on the plywood. You can do the same for the bottom end too. That's how I did it.
I have read on this forum that the side panels will go back on without the need for trimming IF you make sure you don't lift the ply up any further than absolutely necessary. IF you use 15mm blocks, as per the fact sheet, you will most certainly have to trim the side panels.
BTW - trimming the side panels is far easier than you'd think.
Also - if your floor only butts up to the side panels you'll have to do some very very accurate cutting of the ply to make it neat - then again, as long as you are close, and you are using carpet, you could tuck the carpet under the side panels and no one woulde ever know - which is what you are thinking of !
- 8etty 8ongo
- Tribal Elder
Re: New flooring
will get the carpet and everything out on tuesday and see what i have, maybe i will go with 12mm ply then. really dont want to have to cut the sides. what did you use to cut the sides??Dodgey wrote:The Jigsaw is your friend. None of the "shaping" is tricky. My advice is to grab a large amount of cardboard and you can then, with scissors and tape, make a template for the "top"/"front"! half - to draw around on the plywood. You can do the same for the bottom end too. That's how I did it.
also, am going to go with lino as i want to then buy the bongo mat set that will sit on top pf the lino so that i have a choice - lino for day trips to the beach etc and carpet/matting for longer trips where comfort is the key. am excited now as think i know what im doing
- daveblueozzie
Re: New flooring
I used a jigsaw and electric sander to make the sloping panel, i didn't want the ply to end suddenly at the back of the bongo ,some do and just fit a piece of alloy angle to hide the edge.
I stopped about 8 inches short of the rear of the bongo with the ply floor to be able to make the slope.
If you look at my pics you will see i didn't take the side panels off, no need, once you take the old carpet out it leaves a gap under the side panels, i made cardboard templates first, then cut the ply to size, there was plenty of room for the underlay and lino to fit under the side panels making it neat and tidy.
Take your time and make sure you lay any wiring down first, i even added a couple of wires from the front to the back just in case i might need them at some time (not connected to anything but labeled)
- 8etty 8ongo
- Tribal Elder
Re: New flooring
Wiring?????? are you having a laugh????daveblueozzie wrote:If you look at my pics you will see i didn't take the side panels off, no need, once you take the old carpet out it leaves a gap under the side panels, i made cardboard templates first, then cut the ply to size, there was plenty of room for the underlay and lino to fit under the side panels making it neat and tidy.
but thanks for the info about the panels
ahh roll on tuesday and can i have some dry weather please
- daveblueozzie
Re: New flooring
Don't forget a bit of underlay first, the foam type that goes under laminate flooring, stops the wood squeaking on the bare metal and gives a bit of insulation, one pack is enough for under the ply floor and on top of the floor.
- 8etty 8ongo
- Tribal Elder
Re: New flooring
righto thanks, think we might have some of that.
Re: New flooring
Well it sounds like you wont have to cut the sides. I did it with my jigsaw. You have to be pretty confident using it as you end up running the saw over curved surfaces which means at times the blade is not long enough and kicks out. No harm but frightening if you are not ready for it.
As for ply . I used 12mm as thats all wickes had. If you have a timber merchant near by - which is almost a certainty, go there . It will be not far off half the price of b&q or wickes. One sheet will fit in the bongo with a bit of a jiggle.
