One of the drawings that is going in the fact sheet to assist with cooling system.
Well, its not so much of a fact sheet ........ its turned into a book.
Anoher useful drawing.widdowson2008 wrote:Air flow past Bongo when in motion (Bongo that is)
It does protect the engine from all the crap kicked up from the roads, but IMHO, its primary function is to direct the natural flow of air (when moving) and from the scavenger fan (when stopped) up past the engine. If you look at the shape of it, particularly at the front end, you'll see what I mean. Its an AIR SCOOP. The other functions you mention above (again IMHO) are just bonus features.mikeonb4c wrote:Anoher useful drawing.widdowson2008 wrote:Air flow past Bongo when in motion (Bongo that is)
Some people have been on here to ask whether the underbody cover is necessary. Reasons for it being there have generally been given as protecting engine from dirt and grime, and reducing noise from engine compartment. Its good that this other (possible) function is being promoted. I've not studied theBongo underside to see how well the ari scoop theory holds up, but I suspect it is a component in encouraging airflow over the engine block, especially when the scavenger fan is being used.
It would be worth having the airflow arrows show how air enters AND exits the compartment, as well as showing the scavenger fan position and angle of mounting as that would help explain what goes on.
I'm sure you're right. Just need to crawl underneath mine to confirm that hunch. With a little tweaking, the scavenger fan could be used as a charging device when on the move by getting it to windmill (I kid you not)widdowson2008 wrote:It does protect the engine from all the crap kicked up from the roads, but IMHO, its primary function is to direct the natural flow of air (when moving) and from the scavenger fan (when stopped) up past the engine. If you look at the shape of it, particularly at the front end, you'll see what I mean. Its an AIR SCOOP. The other functions you mention above (again IMHO) are just bonus features.mikeonb4c wrote:Anoher useful drawing.widdowson2008 wrote:Air flow past Bongo when in motion (Bongo that is)
If it was just a cover, they could have made it a much simpler shape.
Anoher useful drawing.mikeonb4c wrote:[quote="widdowson2008
Thank you kind sirmikeonb4c wrote:Now THAT (at a quick glance) strikes me as spot on. It would make sense too, in design terms, as it helps ensure cooling air is not forced through the compartment unless the system sensors (or the over-ride switch owner) deems it necessary. Excellent drawing
Funny you should say that. I did notice the wheels were the std 15" alloys and not bling bling 17" ones like wot DBO, MissF and moi have. I didn't notice your nuts were missing though -didn't like to stare too closely - people might get the wrong idea - I'm sure you know how it iswiddowson2008 wrote:Thank you kind sirmikeonb4c wrote:Now THAT (at a quick glance) strikes me as spot on. It would make sense too, in design terms, as it helps ensure cooling air is not forced through the compartment unless the system sensors (or the over-ride switch owner) deems it necessary. Excellent drawing
Don't know if you noticed O eagle eyed one,but the front wheel nuts have actually been put back on the vehicle. (they were missing on the first.)
I throw these in from time to time to see if you are paying attention![]()
Steady on sailormikeonb4c wrote:Funny you should say that. I did notice the wheels were the std 15" alloys and not bling bling 17" ones like wot DBO, MissF and moi have. I didn't notice your nuts were missing though -didn't like to stare too closely - people might get the wrong idea - I'm sure you know how it iswiddowson2008 wrote:Thank you kind sirmikeonb4c wrote:Now THAT (at a quick glance) strikes me as spot on. It would make sense too, in design terms, as it helps ensure cooling air is not forced through the compartment unless the system sensors (or the over-ride switch owner) deems it necessary. Excellent drawing
Drivers door dandy, round the other side.dandywarhol wrote:I'm glad the wheel nuts are on - but how does one get into said vehicle?
