teenmal wrote:...if you use the bleed hose, that is on  the flow not the return,it should  expel the fluid.
I’ve been thinking about this. Bear with me!
The
bleed hose is just a connection onto/off a flowing circuit. Whether it is before or after the pump is purely relative (it’s both!).
With the
bleed hose open to atmosphere the coolant system can’t get pressurised, and as the connection is at the high point there is no reason for fluid to escape.
Unless of course any trapped air in the system circulates round to this point, raises up the hose forcing any fluid in the hose out. There shouldn’t be a constant flow (unless the hose is lowered enough for the “siphon effect” to come into play). Any loss of fluid will be replaced from the expansion tank.
So this is how the “normal procedure” bleeding works, ie
bleed hose held high and open to atmosphere – lets air out (with occasional burbs of forced fluid) as it circulates round to the connection but doesn’t let the coolant flow out. Similarly any air in the radiator circuit can rise up to the expansion tank. The space left by any bled air is replaced by the fluid in the expansion tank (level musn’t drop enough to let air be sucked in).
I’m going to start a bit of an argument now by suggesting that the see saw method might actually restrict the bleeding process.
With the see saw method the
bleed hose is always full of fluid (with an additional head within the funnel). Will this now not make it harder for any air bubbles passing the connection point of the
bleed pipe to exit the system? Perhaps not?
I did notice during my see saw
bleed that revving the engine caused the level in the
bleed hose to drop, I’m assuming this is caused by the venturi(?) effect of the circuit flow past the
bleed connection. Air could then be pulled into the circuit if allowed to drop too far. On idle the levels stabilised.
Revving the engine with the
bleed pipe open to atmosphere (in the “normal“
bleed procedure) wouldn’t  pull any air in. I don’t think. As the flowing coolant hasn’t the same pull on air as fluid.
During the normal
bleed procedure the rev/idle cycles aren’t there to warm the engine as such, but are designed to get any trapped air to the
bleed points (
bleed hose and top hose off radiator to expansion tank). Revving (and consequent speed up of the coolant) forces any air into motion, and then the idle cycle allows this freed air to collect and exit the
bleed points. I think I’ve got this right.
So after repeated cycles all the air should be out. Except of course for the air in the
bleed hose. This can be taken out by simply lowering the hose to the same level as the expansion tank before plugging it.
So what advantages do the see saw or other
alternative methods have over the normal procedure? And have I been correct in my assumptions?
Perhaps I was just lucky with my first coolant change? It’s all very worrying.
