Bongo Fury conversion advice
Moderator: Doone
Hi, new member here, I'm thinking of buying a Bongo and doing the conversion myself. I've got general
Diy experience but not done any vehicle diy, is it someting an amateur could attempt and if so is there a goid instruction manuel anyone can recommend .
Any comments welcome, also if I go ahead what sort of costs could I reasonably expect to incur.
Thanks in advance
Thanks in advance
Re: Bongo Fury conversion advice
Hi, welcome aboard.
I'm not aware of a manual as such, but using the 'search' facility on here will bring up a lot of useful info. Just put 'and' between the words, eg 'self and build and conversion'.
Before commiting I would get along to as many Meets as you can and chat to owners. Look at different set ups and ask questions. The owners won't have a sales pitch and will be honest about what works for them, and what doesn't.
Make certain the Bongo is for you, we love them, but they are ageing and have their quirks. They are small as a camper, good for parking, wild camping, narrow roads, and use as an every day vehicle, but 'cosy' for a family to live in.
Once you've decided on a Bongo I'd live with it unconverted for a season before you start converting, they are a pretty good camper in 8 seater guise. We use some foam mats cut to size to flatten the seats, sleep on the fronts and middle, which leaves room for a loo and space to get changed for bed in the back.
We have a table which goes in front of the middle seat or can be fitted on the bike rack, under the tailgate for outside dinning.
Cost? Could be a couple of hundred, or thousands, just depends how far you want to go...
Hope that helps a bit.
Bob, thanks for the prompt reply, and good advice.
Much appreciated
Much appreciated
This lightweight removable and cheap to build set up has proved incredibly useful and allowed me to retain the full mpv usefulness of my Bongo.
https://photos.app.goo.gl/qzRJmGVMDMX5z6tv8
The top part of the unit can also be used upside down as a side unit with the offside rear seat removed as seen here (the drawer on top of it contains clothes etc and goes on the front ledge of the AFT once the roof is raised:
https://photos.app.goo.gl/aUq7cgZrhueELEDH6
I also made myself a removable drawer to go under the bench seat (and move with it). Also very useful:
https://photos.app.goo.gl/DtBEs1b3eJwQZ4m88
What all this has meant for me is that i'm not committed to one conversion configuration. When i took the kids camping i slept upstsairs and they downstairs, with the tailgate unit and underbench drawer set up as a useful unit in the awning as shown here:
https://photos.app.goo.gl/u83EkKCiXyNeXBgQA
Now i'm travelling and camping solo i have a great one person setup including portapotti and efficient toploading waeco coolbox for which a 100w solar panel on the roof provides more than enough power (and these were purchased using some of the money saved by not doing an expensive conversion).
I must say I like the way Mike is thinking , have a look at slide pods and van essa web sites for more inspiration similar to what Mike is doing . They are based on the ever green VW T5/6 but good as removable camper unit ideas
Brian
Brian
Hello agent n
I have a unconverted bongo which I have owned for over a year now and have used camping frequently. We initially thought about converting, toying with a tail unit then a side conversion, but the more we have used it we are of the opinion the extra space you have unconverted is better suited to our needs (girlfriend and small dog)
Like mike, I have tailored a draw that is on wheels and has two supporting legs which fits neatly under the rear seats, which holds all the essentials including saucepans, frying pan, cooker, cutlery, washing up bowl etc. The legs enable it, when pulled out to form a sturdy table for food prep and cooking. When pushed back it allows us to lay all the seats down, thus having the option to sleep either up top or below on windy days without compromising on internal space. We also have a table inside the van which is attached on a rail below the window line. I added a rail to the draw face which allows me to bring the table outside on nice days.
As for power, I fitted a leisure battery which is powered by a 60watt portable solar panel which allows me to follow the best sun angle throughout the day.
Internal lights have all been changed to LEDs. When not on electric we use a 12v cool box which my solar panel appears to cope well with
As others have mntioned check out as many owner conversions as you can and try using the van unconverted you might be surprised in how it meets your requirements unconverted.
Have fun and enjoy.
Have fun and enjoy.
I assume you need a leisure battery in order for the solar panel to power the cool box at night, what with there being no sun and all? Is that right?
Search on Amazon brings up a few books on van conversations and YouTube has a lot of stuff.
2002 Friendee 2.0 ltr Petrol.
- g8dhe
Cool boxes are NOT a good idea for overnight work, they just draw to much power. If you want 24/7 working then a small compressor fridge with leisure battery and EHU and/or 100 Watt Solar panel will keep you going all the time.
