Cooker problem camping gaz
pollypoo2
Re: Cooker problem camping gaz
Post by pollypoo2 » Sat Jul 07, 2018 9:50 pm
Thank you :)
Post by Bob » Sat Jul 07, 2018 9:53 pm
At £22 it will likely be a lot cheaper to just replace the regulator than have a service person look at it. :wink:
Should be pretty simple.
pollypoo2
Post by pollypoo2 » Sat Jul 07, 2018 9:55 pm
Absolutely. Will give it a go! Thanks again everyone for your help :)
Tessie
Post by Tessie » Sat Jul 07, 2018 9:59 pm
You are right Bob.
It can be a bit fiddly because you are working in the small Wellhouse cylinder cupboard but easy enough to do with only two mounting screws and two hoses to connect. Obviously you need check to make sure there are no gas leaks from the hose connections.
Never run out of road, traction and ideas at the same time.
pollypoo2
Post by pollypoo2 » Sat Jul 07, 2018 10:01 pm
The current one also has an earth connection - does that sound right?
Tessie
Post by Tessie » Sat Jul 07, 2018 10:09 pm
Yes, I think that is earthing the gas pipes so that if they become 'live' because of an electrical problem in the conversion it will blow a fuse.
pollypoo2
Post by pollypoo2 » Sat Jul 07, 2018 10:11 pm
Thank you again!
pollypoo2
Post by pollypoo2 » Sun Jul 08, 2018 3:35 pm
All sorted now and working. The bulkhead regulator was blocked. Has now been replaced 😀
Tessie
Post by Tessie » Sun Jul 08, 2018 4:54 pm
=D> \:D/ Glad it was an easy fix in the end, without paying the 'experts' (so much for their diagnosis of not enough pressure from the Camping Gaz cylinder :roll: )
