Page 3 of 3
Re: DIY Replacement Flooring Progress
Posted: Fri Dec 29, 2017 9:06 pm
by sotal
I had a few lengths of wood in the garage which I chopped up into little pieces. I don't know the size but they were probably about 2cm by 1cm. That is a guess though! I chopped up little blocks and placed them in. Once they were all in place I put a squirt of adhesive on them (think it was pink grip) and carefully placed the ply on top. Then put weights on and left it to dry. I think with the kitchen on top etc. That it would have been ok like that but I decided to use some pre-existing holes near the step to put a couple of countersunk bolts in so that it can't move anywhere.
When I eventually got the step sorted properly I ended up drilling that and putting a couple of coach bolts through. I tried adhesive before but the constant movement as people got in and out made it come off. Two coach bolts completely sorted that though.
Posted: Sat Dec 30, 2017 2:53 pm
by Janner
Ok great. Thank you!
Posted: Fri Oct 04, 2019 9:06 am
by BongoPembs
HI,
I'm about to attempt this on the weekend.
Carpets and all ripped out already and good to go.
Plan on making a cardboard template and going from there.
Just a quick query – how did you managed to fit the ply around the seat runners? Did you leave them in the whole time?
I was planning on leaving them in, but I’m thinking this might cause a bit of trouble when fitting the ply.
Any advice would be appreciated, along with any further words of warning or tips.
Thanks in advance.
Posted: Fri Oct 04, 2019 10:59 am
by Doone
If 'sotal' doesn't see your question, the info on this list might help you. :) https://www.igmaynard.co.uk/bongo/forum ... %2BRunners
Posted: Fri Oct 25, 2019 12:24 pm
by BongoPembs
What thickness wood did you use in between the bumps in the floor?
Posted: Sun Feb 02, 2020 9:26 pm
by Donnie
also going to be attempting this soon :-)
Posted: Sun Feb 02, 2020 9:29 pm
by Donnie
mind you, the factsheet says i don't have privileges to download :-(
Posted: Sun Feb 02, 2020 10:45 pm
by Bob
Have you paid for membership?
The Forum is free to use, but access to the Fact Sheets, and other benefits, means joining the Club.
Not very dear.
Posted: Mon Feb 03, 2020 1:37 pm
by Donnie
Yes, even using the new updated password from January so have access to the members bit but for some reason the floor factsheets the only one i cannot download, says no permission.
Posted: Mon Feb 03, 2020 1:40 pm
by Donnie
https://igmaynard.co.uk/download/floor.pdf is the link for members but definitely not working for me.
Posted: Mon Feb 03, 2020 2:15 pm
by Bob
That's odd. :?
Opens right up here, don't know why.
