This is probably a question already asked. I have just brought the wheel arch trims to my Bongo from eBay. I have safely secured the rears as I have a lip that the thin metal strips can wrap around on the rear arches. However, I cannot see how I can attach the the front trims as there is no lip on the front arches.
Does anybody know how this can be done? Would it be appropriate to use some kind of gum to attach them instead of the thin metal strips?
Thoughts and ideas much appreciated! Thanks!
Front Wheel Arch Trims - cannot safely secure!
Moderator: Ian
- Junior Bongonaut
Re: Front Wheel Arch Trims - cannot safely secure!
You will have a lip, but the plastic wheelarch liner will be touching it. You'll have to push it back to reveal the lip.
The Bongo Bodyshop - For all your Bongo Bodywork needs.
07584 134811
Advice is free.
07584 134811
Advice is free.
- Junior Bongonaut
Thank you for your reply
What do I need to push back, the wheel arch lip itself or the wheel arch trim I have bought?
I would think the liner
- Junior Bongonaut
Ummmm....I don't really won't to cause any damage or interfere with the wheel arch it self really. Is there any particular adhesive that could be safely used?
Sikaflex is a product that gets mentioned a lot. Have a google to see if it might meet your needs. Mask off paintwork though as its horrible stuff if it gets where it shouldn't. Also, it may need some time to set so you might need a way of clamping trim to bodywork while it does.
- Junior Bongonaut
Thank you Mikeon. I have a look into that.
