Voltmeter gauges
Moderator: Ian
richlizard
Voltmeter gauges
Post by richlizard » Tue Feb 02, 2016 12:57 pm
Anyone know where I can get some of these?
I saw them on a dashboard earlier and thought what a good idea.
rita
Re: Voltmeter gauges
Post by rita » Tue Feb 02, 2016 1:39 pm
richlizard
Post by richlizard » Tue Feb 02, 2016 2:30 pm
Thanks Rita.
I did look on Ebay first, but couldn't see anything similar to my image.
Do you have a direct link? Your link was empty.
Post by Bob » Tue Feb 02, 2016 3:17 pm
richlizard
Post by richlizard » Tue Feb 02, 2016 5:23 pm
Thanks Bob.
That looks like the exact individual gauge, but I was wondering if anyone had seen the whole unit around. First picture didn't show it too well, but you can see it better here. Looks real neat and tidy.
Post by Bob » Tue Feb 02, 2016 5:31 pm
You would normaly buy the instruments and surround (its called a binacle) separately.
Idea being peeps will choose different gauges. These used to be available in accessory shops but I haven't looked in a long time.
Ah, this type of thing:
http://www.amazon.co.uk/Generic-Tripple ... B00N5NJ7F8
Post by g8dhe » Tue Feb 02, 2016 5:31 pm
See Image
Image Spherical Visions
rita
Post by rita » Tue Feb 02, 2016 6:41 pm
Post by mikeonb4c » Wed Feb 03, 2016 12:14 am
richlizard wrote:Anyone know where I can get some of these?
I went for something discreet in the form of an inexpensive flush fitted LED unit, seated by making a gasket from old mousemat. This one only monitors LB voltage but you could make it switchable between LB and SB (click image to enlarge):
The big switch below and to the right is a 3 way switch for the 100W spots (on with lights/off/on with main beam only)
The LED voltmeter can be bought on ebay for around £5. For example:
http://www.ebay.co.uk/itm/12v-24v-VOLTM ... xyjP1R5Ev7
(though 'm not sure if this one is the right size so you'd need to check).
richlizard
Post by richlizard » Wed Feb 03, 2016 11:42 am
That's great, thanks a lot guys.
nth
Post by nth » Thu Feb 04, 2016 11:54 am
I went for this setup, flush fitting so not too intrusive. Monitors both batteries at the same time.
http://igmaynard.co.uk/bongo/forum/view ... 44&t=70349
95 2.5d 4WD AFT
Post by mikeonb4c » Thu Feb 04, 2016 2:11 pm
nth wrote:I went for this setup, flush fitting so not too intrusive. Monitors both batteries at the same time.
Yes that's a really nice set up. I just hate doing anything that might not be reversible like cutting into the headlining. But that's just a personal thing.
Return to “Pimp My Bongo”
